GL1500 Front Brake Lever Binding - Steve Saunders Goldwing Forums
 3Likes
  • 1 Post By Robbie G
  • 2 Post By corkya
post #1 of 9 (permalink) Old 06-27-2019, 08:38 PM Thread Starter
Robbie G's Avatar
Year: 1994
Model: GL1500 SE
When my bike is still, and I firmly squeeze the front brake lever, it feels like it is binding or sticking as it is squeezed towards the lever..... in steps.
Is this a sticking master cylinder piston ? ( seal swell or warn piston ?)
No leaks and the brake seems to have proper strength.
Robbie G is offline
post #2 of 9 (permalink) Old 06-27-2019, 09:30 PM
Pure Texas's Avatar
Make: Goldwing
The puck May be seizing in the caliper,how long has it been since the fluid was changed.
1968 Kawasaki Avenger
1969 H1 Kawasaki
1975 1000
1985 LTD
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
Pure Texas is offline
post #3 of 9 (permalink) Old 06-28-2019, 12:08 AM
captdecker's Avatar
Year: 1989 GL1500,2006 GL1800
Make: honda goldwing's
Model: gl1500,GL1800
The bolt for the lever to tied? The brass collar and rod lubed?
captdecker is offline
post #4 of 9 (permalink) Old 06-28-2019, 05:59 AM
That seems to be a common thing and not a problem. My theory is the brake lines getting old and expanding cause the gritty feeling. As long as the brakes work and don't leak I wouldn't worry about it.
post #5 of 9 (permalink) Old 06-28-2019, 09:29 AM Thread Starter
Robbie G's Avatar
Year: 1994
Model: GL1500 SE
Installed braided steel brake line with fresh fluid change out. Lever is new with brass liner. Caliper does not stick at all.
Robbie G is offline
post #6 of 9 (permalink) Old 06-28-2019, 09:36 AM Thread Starter
Robbie G's Avatar
Year: 1994
Model: GL1500 SE
OK, new update. As I squeezed the lever and stooped down next to the right front caliper, I heard the caliper actually clicking as I squeezed slowly on the lever. The caliper was actually making a clicking sound with a vibration with each click.
The caliper completely releases when I let up on the lever, no leaks and has proper strength. Only does this when squeezing lever slowly and firmly..... normal ?
Robbie G is offline
post #7 of 9 (permalink) Old 06-28-2019, 03:22 PM Thread Starter
Robbie G's Avatar
Year: 1994
Model: GL1500 SE
So I took that caliper off the bike completely cleaned it checked it over and it looks absolutely perfect. lubed up the brake pad mounting pens after sanding them with 800 grit sandpaper. Put it all back together and squeeze the lever some more and look everything over once again. It is making this sound louder by The master cylinder itself so it is probably the piston that is dragging in there.
limpy45 likes this.
Robbie G is offline
post #8 of 9 (permalink) Old 07-09-2019, 09:40 PM
corkya's Avatar
Model: 1999 GL1500 Aspencade
My front brake lever would not pull smoothly through its travel, so I pulled the lever cleaned the brass bushing it with my pistol cleaning wire brush, cleaned the entire area with basic cleaning stuff, put white lithium grease on every metal to metal contact point. It's so smooth now I can hardly tell I have actually pulled it in.
DBohrer and limpy45 like this.
corkya is offline
post #9 of 9 (permalink) Old 07-09-2019, 09:51 PM
DBohrer's Avatar
Year: 1967
Make: BSA Royal Star
Corkya gets the nod on this one.
I seem to remember him having that issue....!
DBohrer is offline
