97 wing exhaust hot - Steve Saunders Goldwing Forums
 2Likes
  • 2 Post By redwingrider3
post #1 of 6 (permalink) Old 07-03-2019, 03:43 PM Thread Starter
redwingrider3's Avatar
Year: 1975/1997/2016
Make: 3 goldwings
Model: gl1000/asp1500/1800
97 wing exhaust hot
97 wing engine left exhaust a lot hotter than right side. engine has no power stalls out then runs fine then stalls out again.
new fuel pump new vacuum gas valve new fuel filter gas cap ok . Carbs rebuilt ran fine 3 weeks now doing same thing again.
Any ideas?
Steve
redwingrider3 is offline
post #2 of 6 (permalink) Old 07-03-2019, 05:42 PM
DBohrer's Avatar
Year: 1967
Make: BSA Royal Star
Your engine needs four things to perform well.
Fuel, Ignition, Air and Breathing.
Ignition, Air and Breathing would not cause just one side to run hot.
What's left.....?? Could it be carburation....??
Any ideas?
DBohrer is offline
post #3 of 6 (permalink) Old 07-18-2019, 06:39 PM Thread Starter
Make: 3 goldwings
Thumbs up 97 wing hot exhaust solved
Improper float setting and two bad vacuum pistons with split diaphragms. Guess that's what 22 years and lousy gas does. Runs like a watch now. Thanks DBohrer
AZgl1800 and flylow like this.
Steve
post #4 of 6 (permalink) Old 07-18-2019, 07:03 PM
Did you peek in to see if the slide is stuck open while acting up?
redwing52 is offline
post #5 of 6 (permalink) Old 07-18-2019, 09:23 PM
Sounds like you found the problem. Good job!!
limpy45 is offline
post #6 of 6 (permalink) Old 07-19-2019, 10:24 PM Thread Starter
Make: 3 goldwings
They worked looked normal when you cracked the throttle so never gave it anymore thought.
Steve
