Cooling fan running too much - Page 2 - Steve Saunders Goldwing Forums
 5Likes
post #11 of 13 (permalink) Old 07-13-2019, 02:47 PM
Year: 1988
Model: GL1500
Either the fan temperature sensor is reading wrong or the gauge/gauge sensor are faulty
Bryanlj is offline
post #12 of 13 (permalink) Old 07-14-2019, 11:58 AM Thread Starter
Matt78Gl1000's Avatar
Year: 78
Make: Honda Goldwing
Model: GL1000
Originally Posted by tlbranth View Post
The OEM switch seems to cause problems sometimes. Mine would come on at more or less the right temp but then stay on. I disassembled and cleaned it to no avail. Then I replaced it with an automotive switch and matching connector. I wired in a relay for it too. It works fine and a replacement is cheap and easy to find. I documented my efforts on NGW here: https://www.ngwclub.com/forum/viewto...switch#p714582
Mine will eventually shut off. Just seems like it takes way to long. I have about a 40 min ride home, and yesterday at every single stop light I would check and it'd still be running even with the guage on the cool side it was running, I'll definitely check out the switch
Matt78Gl1000 is offline
post #13 of 13 (permalink) Old 07-14-2019, 11:59 AM Thread Starter
Year: 78
Model: GL1000
Thanks! I'll probably start with the fan sensor
