1982 GL1100A Spark just quit - Steve Saunders Goldwing Forums
 2Likes
  • 1 Post By DaveO430
  • 1 Post By bmcfarris
post #1 of 7 (permalink) Old 07-07-2019, 05:12 PM Thread Starter
bmcfarris's Avatar
Year: 1982
Model: Gl1100A
So I have completed my rebuild of my 1100. I discovered that I had aligned the left side pulley with the middle of the cylinder head instead of the left timing mark which is one notch below middle. This cost me the #4 Piston, the left side cylinder head and having to clean out little bits of piston from the entire casing. I now have a much greater understanding of how these amazing engines were designed. I started the rebuilt motor and it ran much better than it did before, amazing. I shut it down for the evening. I went to start it again the next day and it started to fire up one time and then no more spark, on any of the plugs. I confirmed this with my good ole xenon timing light that I have used before successfully on this bike. What did I do to kill it this time or is it just trying to torment me???
1982 GL1100A Shade Tree Refugee
bmcfarris is offline
post #2 of 7 (permalink) Old 07-07-2019, 07:00 PM
The first thing to check is the kill switch. 1100s have 2 complete separate ignition systems with the power feed being almost the only thing they have in common besides the pulse rotor.
post #3 of 7 (permalink) Old 07-07-2019, 07:15 PM Thread Starter
bmcfarris's Avatar
Year: 1982
Model: Gl1100A
I have verified proper operation of the Run-Stop switch and the Clutch interlock. According to my Clymer book the Pulse generator measures correctly also. Thank you for your input though.
post #4 of 7 (permalink) Old 07-07-2019, 09:56 PM
The clutch interlock has nothing to do with ignition, it is for the starting system. Have you checked for power to the coils?
post #5 of 7 (permalink) Old 07-08-2019, 08:27 PM Thread Starter
bmcfarris's Avatar
Year: 1982
Model: Gl1100A
How does one check power to the coils on this model?
post #6 of 7 (permalink) Old 07-08-2019, 09:56 PM
Check for voltage on the black/white wire to the coils.
OldSchool_IsCool likes this.
post #7 of 7 (permalink) Old 07-09-2019, 09:32 PM Thread Starter
bmcfarris's Avatar
Year: 1982
Model: Gl1100A
Mystery solved. Referencing the parts list for the Alternator. part #11 92000-06014 is NOT the short 4th bolt that alternator casing on. It goes into the Pulser shaft to prevent part #3, the Advancer assembly from backing out like mine did. Non-Professional/Shade Tree mechanic error. Time to put the Refugee back together. I'm getting pretty good at this.
limpy45 likes this.
