Oil Seal '95SE - Page 2 - Steve Saunders Goldwing Forums
 3Likes
post #11 of 16 (permalink) Old 07-08-2019, 03:57 PM
CrystalPistol's Avatar
Originally Posted by Gary Neppell View Post
I just unpacked the service manual for The 95 GL 1500
There is no oil seal behind Coupler A to the engine block
Coupler B to the alternator has an oil seal right behind that on the shaft For this particular year
Iím going to yank out the non-OEM Hitachi and reinstall my rebuild Compu fire with a new o-ring
I had that fellow in Indiana rebuild it havenít had a chance to put it back in
Thank you for all the replies
Seal on shaft behind drive hub of Comp-u-Fire is Chicago Rawhide # 9878 or National # 471224
...(Candy Spectra Red )
CrystalPistol is offline
post #12 of 16 (permalink) Old 07-08-2019, 04:03 PM
it should have had a seal, even though it was not there on the Hitachi.
post #13 of 16 (permalink) Old 07-09-2019, 06:47 AM
DBohrer's Avatar
Year: 1967
Make: BSA Royal Star
I have a 1996 Honda Manual and the "oil seal" is shown in the manual. See attached.....!
In the parts diagram (Partzilla) that oil seal is shown (item # 8) for the 1996 through 2000.
However, it is only listed in the (parts list) for the 1998 - 2000 years. The same oil seal fits all years.....!
Not necessarily uncommon for this kind of thing to happen.......
Honda lists the right rear shock (boot) available separately for the 1988 - 1993. However, not listed separately for the 1994 - 2000. Same boot fits all years.....!!
Sometimes we need to think "just a little" outside the box...............
corkya likes this.
DBohrer is online now
post #14 of 16 (permalink) Old 07-11-2019, 06:27 PM
Year: 2003
Model: GL1800 Trike
ChiefBob is offline
post #15 of 16 (permalink) Old 07-11-2019, 08:35 PM
goldwinger11's Avatar
Year: 1992
Model: GL1500 Aspencade
It looks like the seal is not designed as a user serviceable onei have a few alternators in my shop which I’ll check.
1985 GL1200 with a 16 ft wood canoe and Champion sidecar.
goldwinger11 is offline
post #16 of 16 (permalink) Old 07-15-2019, 12:05 PM
AApple's Avatar
Year: 1981, 1996
Make: Honda GL1100 GL1500
Model: Innerstate
OE # for original seal is 31104-MN5-005. it will NOT fit an aftermarket alternator, but it is correct for the OE Honda(Hitachi) alt. Just put one on my '96.
AApple is offline
