1984 GL1200 fork rebuild - Steve Saunders Goldwing Forums
post #1 of 18 (permalink) Old 07-09-2019, 12:44 PM Thread Starter
TonimusMaximus's Avatar
Year: 1984
Model: GL1200I
I've found a couple of good threads on the how to do the fork rebuild, but I haven't found anyone listing the complete set of consumables to do a fork rebuild. Does anyone out there have that?
A well regulated militia, being necessary to the security of a free state, the right of the people to keep and bear arms shall not be infringed.
TonimusMaximus is offline
post #2 of 18 (permalink) Old 07-09-2019, 01:12 PM
What do you mean by consumables? It's about a 2 six-pack job.
The '84 has different innards than the later models. You might want to plan on some Progressive springs if the bike doesn't already have them.
Each fork takes 10.9 oz of fluid. With stock springs, ATF. With Progressives, 15W.
https://shop.westernhonda.com/fiche_...984&fveh=13046
post #3 of 18 (permalink) Old 07-09-2019, 02:27 PM Thread Starter
Year: 1984
Model: GL1200I
I'm talking about a full list of wear items. Bushings, seals, etc. I am adding progressive springs and 15 weight oil.
post #4 of 18 (permalink) Old 07-09-2019, 02:54 PM
DBohrer's Avatar
Year: 1967
Make: BSA Royal Star
Tonimus, You have a private message.....that should help....!
Depending on your weight, two-up riding etc. etc., you may want to use 10 wt with the Progressive springs.
I am not a "full figured" person and I am using 10 wt fork oil......!!
Ah yeah, I am aware of what Progressive recommends. But that doesn't always work best for everyone.....!!
Just like shoes......one size doesn't fit all.....................
DBohrer is offline
post #5 of 18 (permalink) Old 07-09-2019, 03:03 PM
If it's your first time with this bike, I'd say get the seals and bushing up front.
The '84 has and extra set of bushings.
Look at the fiche and make sure you have the needed o-rings. Some, like #61, you have to get from Honda. I think, no matter how carefully you plan, you always end up needing to run to a parts store for an o-ring or washer.
post #6 of 18 (permalink) Old 07-09-2019, 04:02 PM Thread Starter
Year: 1984
Model: GL1200I
The list I came up with:
#68x2 top bolt o-ring
#65x4 air crossover o-rings
#39x2 Fork seal set
#15x2 backup ring
#16x2 guide bushing
#17x4 slider bush
#60x2 special washer
#69x2 (I think this is the anti-dive housing molded o-ring)
#66 should also be on the list but isn't available. 37.5x2mm o-ring. I think this is a JIS S38 o-ring.
post #7 of 18 (permalink) Old 07-09-2019, 05:31 PM
The newer wide lower bushing replaces the 2 narrow ones on the 84. The superseding # is on the fiche but the amount required still says 4 instead of 2.
post #8 of 18 (permalink) Old 07-09-2019, 05:50 PM Thread Starter
Year: 1984
Model: GL1200I
Is #15 backup ring a wear item that should be replaced?
post #9 of 18 (permalink) Old 07-09-2019, 07:51 PM
DBohrer's Avatar
Year: 1967
Not a wear item, you don't need to replace it.
Did you see it on the list I sent you.......???????????? I don't think so.....!!
DBohrer is offline
post #10 of 18 (permalink) Old 07-10-2019, 12:32 PM Thread Starter
Year: 1984
Model: GL1200I
Yes I did. I just wanted to make sure I had everything I may need. Western Honda is only 20 minutes from my house, so I can save on a delivery fee.
