How to remove rear tire - Page 2 - Steve Saunders Goldwing Forums
 16Likes
post #11 of 54 (permalink) Old 07-21-2019, 09:56 PM
Originally Posted by Indianawantsme View Post
2012
PIA do take passenger arm rests off, seat off, .
I'm curious what would be the point of taking the seat off to change the rear tire?
post #12 of 54 (permalink) Old 07-21-2019, 10:05 PM
Indianawantsme's Avatar
Model: 2012 GL1800
IF you are not doing the layover method. OR don't have a lift to drop the wheel down.
You have to take the seat off to get to the amplifier connector to disconnect and fish it back up to reconnect.
Steve E.
2012-GL1800- 34,700 miles
88-GL1500-124k+ mi. SOLD
78-Honda CB750K- 72k+ mi.
67-Suzuki 250cc T20-X6 Hustler-fun to ride yet
Bridgestone Exedra- front
Pirelli Snow Control 3-R/F
8800mi on it so far @36psi and less
Pirelli Centurato P1 87V R/F-took off with 14.5k on it and mounted new P1. Maybe 2k more left but had small cut, so in trash.
34-36psi.
Indianawantsme is offline
post #13 of 54 (permalink) Old 07-21-2019, 10:52 PM
good reason to not put any electronics in the trunk
post #14 of 54 (permalink) Old 07-21-2019, 11:07 PM
Model: 2012 GL1800
Amplifier is stock Honda above rear wheel in inner fender.
The owners manual shows how to remove rear wheel.
Steve E.
34-36psi.
post #15 of 54 (permalink) Old 07-21-2019, 11:36 PM
just lay it over, and be done with it in 5 minutes.
pidjones likes this.
post #16 of 54 (permalink) Old 07-22-2019, 05:35 AM
Thank you. I was having a bad case of what the ____.
post #17 of 54 (permalink) Old 07-22-2019, 05:59 AM
DenverWinger's Avatar
First step for just about anything (especially on a 1500) is "remove the seat". At least you don't have to do that to check the oil....
Bellboy40 likes this.
1972 CL-350 (1980-1988) sold
1977 GL1000 (2002-2006) sold
1993 GL1500 Aspencade (2017-)
1983 Trav-Lite Camper (2010-)
DenverWinger is offline
post #18 of 54 (permalink) Old 07-22-2019, 11:12 AM
Year: 1985
Model: Interstate
If you have a trailer to put ot on or a lift:
Use center stand and strap it so it can't fold up. Drag the bike back to hang the rear wheel in mid air and strap the bike down.
Sprocketrocket55 is offline
post #19 of 54 (permalink) Old 07-23-2019, 05:50 PM Thread Starter
Drnick's Avatar
Year: 2016
Model: Nav,ABS
Frankly laying a new,$25000,900 pound bike on its side,and hoping for no damage is a roll of the dice! And using a lift that jacks up bike on the motor and exhaust pipes( there is no downtube
aka like a Harley,and it’s possible u can dent the exhaust pipes, so I guess I’ll follow the manual,and take the extra 20 minutes (I hope) to remove tire, but thanks for all the advice.
Drnick is offline
post #20 of 54 (permalink) Old 07-23-2019, 07:29 PM
You don't lift it by the exhaust pipes. One pad goes under the center stand pivot and the other under the front of the engine. The only way it gets damaged laying it on it's side is if you have some kind of mishap or lay it on bare concrete, gravel etc.
