'84 GL1200 front brake switch cleaning - Steve Saunders Goldwing Forums
 4Likes
  • 4 Post By TonimusMaximus
post #1 of 4 (permalink) Old 07-21-2019, 03:33 AM Thread Starter
TonimusMaximus's Avatar
Year: 1984
Model: GL1200I
The front brake switch on my GL1200I was acting up. I could buy a new switch on Amazon for like $8, but it'd be here Wednesday and I've got a lot of riding to do between now and then. Ultimately, it is just a microswitch and should be able to be cleaned. Here's what I've done tonight. The guts are sitting in vinegar overnight and will be reassembled in the morning.
Cover with 3 heat stakes drilled out:
Untitled by bigangryscot, on Flickr
Inside cover:
Switch guts:
A well regulated militia, being necessary to the security of a free state, the right of the people to keep and bear arms shall not be infringed.
TonimusMaximus is online now
post #2 of 4 (permalink) Old 07-21-2019, 06:33 AM
DenverWinger's Avatar
I've had to do that on my 1100, Effective...
I'd get a new switch but don't know what to get. Many years ago I had to replace the master cylinder because the reservoir was disintegrating. Found another master cylinder at the local motorcycle "pick-and-pull" breakers which was on a dual front disk bike and it works fine on the 'Wing. Problem is, I forgot to note what bike it came off of. It wasn't a Honda....
1972 CL-350 (1980-1988) sold
1977 GL1000 (2002-2006) sold
1993 GL1500 Aspencade (2017-)
1983 Trav-Lite Camper (2010-)
DenverWinger is offline
post #3 of 4 (permalink) Old 07-21-2019, 11:18 AM Thread Starter
Year: 1984
Model: GL1200I
Next morning, wiped down with scotchbrite and used a fingernail file to clean the corroded contact point.
I put a little CA glue on the plastic studs and screwed it back on to the bike. No more issues!
post #4 of 4 (permalink) Old 07-21-2019, 04:35 PM
hey, you did alright!
