1985 Aspy. Gear selctor - Steve Saunders Goldwing Forums
post #1 of 6 (permalink) Old 07-22-2019, 10:21 PM Thread Starter
highriderzr2guy's Avatar
Model: 85 aspy
I have a 1985 GL 1200 aspencade. Digital dash. With a gear selector that tells me what gear I'm in. Gear number 2 does not display and it is hard to get the neutral (N) to display. All of the other gears Display just fine. Any ideal where I need to look to fix these problem? It is no problem to ride that way but I just like everthing to work. Roger H.
highriderzr2guy is offline
post #2 of 6 (permalink) Old 07-23-2019, 04:26 AM
Probably the gear position switch inside the trans front cover but you could check the connections.
post #3 of 6 (permalink) Old 07-24-2019, 08:35 PM Thread Starter
Model: 85 aspy
You say inside the trans front cover. Do you have to remove engine to get to that?
post #4 of 6 (permalink) Old 07-24-2019, 09:54 PM
No, you do not.
post #5 of 6 (permalink) Old 07-24-2019, 10:36 PM Thread Starter
Model: 85 aspy
Well that is good to hear . I will look at my service book and see all what needs to be done to it. Thanks.
post #6 of 6 (permalink) Old 07-25-2019, 10:16 PM
Mine does the identical. Thanks in advance
rcgreaves is offline
