Please help me restore this old GL1200 - Page 4 - Steve Saunders Goldwing Forums
 3Likes
post #31 of 36 (permalink) Old 08-10-2019, 12:31 PM
I would definitely rebuild the Honda systems, and if you need a fuel pump, I believe new ones are still available from Honda. Pay the price as they are worth the extra money.
That bike isn't that bad. I helped a friend recondition an '84 that was in worse shape.
These example pics show basically what we started with and what some labor transformed.
post #32 of 36 (permalink) Old 08-14-2019, 02:27 AM Thread Starter
Fatboy123's Avatar
Year: 1984
Model: GL1200 Standard
I'm very grateful to you all for pushing me along.
I ordered a bunch of parts, timing belt and all other maintenance items, but since I live in Kuwait it'l take a good month or so until I get them.
Meanwhile I removed the carbs and cleaned them using guides from here, I removed the secondary air unit (picture 1), purely for ease of carb removal, cleaner looks and the fact that I'm a minimalist so it gave me immense joy, I used a steel plate and some RTV sealant to cover that hole, picture 2.
Then I went to a local machine shop and had them make me four plugs for the holes on the engine, picture 3.
1984 GL1200
Fatboy123 is offline
post #33 of 36 (permalink) Old 08-14-2019, 04:02 AM
I understand you are in Kuwait, but your voice sounds upper eastern USA.
Are you over there as a teacher?
I'm an OkieTexMex guy and had no problems understanding you at all.
post #34 of 36 (permalink) Old 08-14-2019, 06:03 AM Thread Starter
Fatboy123's Avatar
Year: 1984
I'm an OkieTexMex guy and had not problems understanding you at all.
Thanks John, I'm from Iran, but lived and worked most of my life here in Kuwait, raised a family and now work as a warehouse manager in a transport company.
AZgl1800 likes this.
1984 GL1200
post #35 of 36 (permalink) Old 08-14-2019, 06:17 AM
I do hope you mean belts, as in 2 of them.
post #36 of 36 (permalink) Old 08-14-2019, 07:05 AM Thread Starter
Fatboy123's Avatar
Year: 1984
Yes Dave, I ordered:
2 Timing belts
2 Air filters
5 Oil filters
Spark plugs
Solenoid
Rectifier
3 brake pad sets
Carb rebuild kit
Fuel filter
Fork seals and some other miscellaneous parts.
For the brakes I have a bit of dilemma, both the brakes and clutch master cylinders need a rebuild kit and both the sight glasses are broken with a lot of corrosion and rust inside, both the diaphragms are also torn, individual oem parts are very expensive for this bike so I just both two new sets for Honda Valkarya for 30$ that will fit my bike (picture 1), the only snag I see with this setup is that I won't be able to use the choke lever, for that I bought a Harley choke pull cable (picture 2), I think I can make a small bracket somewhere down near the carbs to fit this.
1984 GL1200
