Brake and clutch lines bad - Steve Saunders Goldwing Forums
  • 1 Post By Bike...and Dennis
post #1 of 6 (permalink) Old 08-15-2019, 09:43 AM Thread Starter
4evermetric's Avatar
It's been a few years since riding my 87 GL1200, and while it fires up fine, the clutch is spongy and not disengaging, and the rear brake is also spongy and not working. Where should I start to fix these? Both resevours have fluid.
Thanks for your kind assistance.
Gun totin', motorcycle ridin', whisky drinkin', meat eatin' American. That's who I am...
2000 Valkyrie
1987 GL1200
1996 Motoguzzi Cali
Joined the Darkside-03.28.2010
Iron Butt Association, #38226
Robert Morris Lodge #97F&AM
4evermetric is offline
post #2 of 6 (permalink) Old 08-15-2019, 10:48 AM
Welcome back.
Have you tried bleeding the systems?
CrystalPistol likes this.
post #3 of 6 (permalink) Old 08-15-2019, 01:10 PM
CrystalPistol's Avatar
Welcome back.
Would be where I'd start.
...(Candy Spectra Red )
CrystalPistol is online now
post #4 of 6 (permalink) Old 08-15-2019, 02:56 PM
BLUTHUNDR31's Avatar
Yup, ,bleed both systems, ,I found that "speed-bleeders" work the best if you don't have someone to help. New DOT 4 fluid in each system for sure.
Additionally, that clutch reservoir will need to be cleaned out to remove that brownish "gunk" that collects in it with old(ish) fluid. There is a small shiny silver "tab" inside that needs to be gently pried up/off and using a tiny probe (torch tips worked best for me), clean out the "return" line and your clutch problems should be solved. The front brake reservoir might have the same "gunk", so make sure its cleaned out too.
OOPS, , , just noticed you're speaking of a 1200, , , my experience is with the 1500's so disregard anything that doesn't apply, , ,
BLUTHUNDR31 is online now
post #5 of 6 (permalink) Old 08-15-2019, 08:31 PM
I've seen rebuild kits on ebay, when bleeding does not do the job.
first wing 76 bought new 78, owned 1 gl1000, 2 gl1100, 4 gl1200 (two standards), 2 gl1500, valkyrie 97 , stable now just 2 gl1200 standards.
bajadean is offline
post #6 of 6 (permalink) Old 08-16-2019, 02:49 PM
Average Goldwing Rider
JamesPal's Avatar
Year: 1972, 1981, 1985
Make: CB450, GL1100, GL1200I
How many years has it been since the bike was used regularly? More the 3 I would strip the masters, slave and calpers. If the brake likes are original I would replace them too.
Jim Palmer
Current rides:
\'85 GL1200I Garage Find
\'81 GL1100 Std
\'72 CB450K5
My \'81 Restoration:
JamesPal is offline
