2012 radio “pop” - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 08-23-2019, 12:21 AM Thread Starter
Anton4's Avatar
Model: 2012 GL1800
2012 radio “pop”
This just started a few weeks ago. When I turn the key on, there’s a loud pop from the speakers. It happens a few times, then stops. The presets are all lost but everything works fine...until the next time I turn on the key. The clock doesn’t lose time. Any ideas on what the problem might be? Thanks.
Anton4 is offline
post #2 of 5 (permalink) Old 08-23-2019, 02:32 AM
I don't know if the clock is on the same fuse as the radio presets are or not.
but it sounds like the Backup Memory fuse is open.
post #3 of 5 (permalink) Old 08-23-2019, 08:49 AM
cihilb's Avatar
Model: 2012 Pearl White
Is the A SEL button pushed? This can cause strange problems.
cihilb is offline
post #4 of 5 (permalink) Old 08-23-2019, 11:03 AM
joe in calif's Avatar
I had that happen on my 02 Wing. When I picked it up from the frame re weld. The SEL button was depressed.
A NEW START ON 1/20/2017
joe in calif is offline
post #5 of 5 (permalink) Old 08-27-2019, 09:05 AM Thread Starter
Anton4's Avatar
Model: 2012 GL1800
Thanks for the help. The issue has been solved though I’m not quite sure how. It may have been the A Sel button but I can’t replicate the problem. All is well again.
Anton4 is offline
