Is using balancing beads a no-no? - Page 3 - Steve Saunders Goldwing Forums
 28Likes
post #21 of 23 (permalink) Old 09-10-2019, 01:33 PM
CrystalPistol's Avatar
Originally Posted by ALEX BERECZKY View Post
I've never tried Beads, myself... yet always wondered if you are supposed to Balance the Beads, before installing them?
And how exactly do you balance those little things?... I put them atop my bubble tire balancer, but could hardly get a reading.
Guess my fear is, if I use Un-balanced beads, then the whole wheel will inherit that wonky dynamic; perhaps causing a lean to one side or the other.
I use a pin mounted in my big vise, just balance them on the tip, & then I use my belt sander to take off excess weight if needed. Tried the grinder but that didn't work out too well, it took too much off too fast.
...(Candy Spectra Red )
CrystalPistol is offline
post #22 of 23 (permalink) Old 09-12-2019, 06:55 PM
bamaTrider's Avatar
While we’re on this subject, does anyone have experience using beads in an inner tube?
1999 Honda VT1100T Ace Tourer
\'04 GL1800 Goldwing (previous),
and now '04 GL1800 with CSC Cobra trike
bamaTrider is offline
post #23 of 23 (permalink) Old 09-12-2019, 06:57 PM
that is specified as an ABSOLUTE NO NO by DynaBeads.
