Unknown harness connected into factory RR anyone ever seen this? - Steve Saunders Goldwing Forums
post #1 of 6 (permalink) Old 09-04-2019, 09:55 AM Thread Starter
Year: 1984
Model: GL1200 Aspencade
I was re assembling my bike and noticed this jumper harness that looks like it would be connected inline with my RR harness it has a male and a female plug and 2 wires that go direct to chassis ground. It's connected to a black shrink-wrapped piece that's zip tied to the bracket. There are 2 small gauge hot and ground wires that connect it in. I'm at a loss my parts bike doesn't have this.IMG_20190903_133242_1567608730818.jpg
Linus is offline
post #2 of 6 (permalink) Old 09-04-2019, 10:15 AM
CrystalPistol's Avatar
Looks some vaguely familiar, seems it was from long ago. I'm thinking it was maybe a harness to add capacitors (maybe what's in that shrink package) to cut noise and to better ground to reg/rectifier. The shrink wrapped item with zip tie was the item that jogged my memory. I know I've looked at something similar good number of years ago, but I don't recall buying one. Back in the late '90s, I did add extra grounding myself, I was working through my own CB install.
...(Candy Spectra Red )
CrystalPistol is offline
post #3 of 6 (permalink) Old 09-04-2019, 10:43 AM
Bellboy40's Avatar
Year: 2000 & 1994
It likely was a harness to reduce the noise in the intercom. I remember installing a kit for doing just that on the GL1200 LTD I used to have. It had a crackling/white noise in the intercom when riding and that eliminated most of the unwanted noise.
Larry
-- Albert Einstein
Bellboy40 is offline
post #4 of 6 (permalink) Old 09-04-2019, 10:46 AM
I have seen something similar, it is a radio noise suppressor. They are known to cause charging problems but yours may be a different type that may not cause problems.
post #5 of 6 (permalink) Old 09-04-2019, 11:41 AM Thread Starter
Year: 1984
We use the Sena SMH series intercoms so I can just remove the unit?
Linus is offline
post #6 of 6 (permalink) Old 09-04-2019, 02:51 PM
I think so. My '85 only had a 5 pin mini DIN capped off and laying under the left fairing pocket, so I bought mini DIN extension cables with ends (Radio Shack), spliced them to make a tee, and wired in rider & co-rider outlets for headsets (could have used a junction box from J&M I guess), and I had a lot of noise. My cure was found one day by running the co-riders wire set down as low as I could along the right side of the bike, wrapped in foil & tape grounded, even tying the cable below top of fuel tank (so FT metal hid it from the yellow wires) as best as I could, and away from those three yellow wires from stator.
