Searching for answers for 1984 GL1200I, running very poorly - Steve Saunders Goldwing Forums
 5Likes
post #1 of 12 (permalink) Old 09-04-2019, 01:29 PM Thread Starter
Year: 1984
Make: Honda GL1200I
Model: Interstate
My bike is running on 2 cylinders, 3 & 4 are dead, I'm getting a spark at both cylinders but it seems too weak to fire the plugs. New plugs, swapped out the coils and recently cleaned and rebuilt the carbs. My next step is to test the pulse generators. Does anyone have any other ideas?
James McConnell is offline
post #2 of 12 (permalink) Old 09-04-2019, 01:52 PM
Sounds like you're doing it right. Make sure you check all the connectors. I've seen the pins loosen and move on these old plugs.
I'll move this to the Technical Forum. You'll get more help there.
James McConnell likes this.
post #3 of 12 (permalink) Old 09-04-2019, 02:48 PM
It aint rocket science
DriverRider's Avatar
Model: The best
First things first is to do a compression test on the engine. You write that there is spark, I assume that you assume it has to be ignition related because you had the carbs off yet you do have spark. How did you test to verify fuel is getting to and through those carbs to the intake?
J.D.
Internet myth buster
Starter ride
Rupp
Previous rides
Bultaco
Yamaha 360
Yamaha 650
WS Grand Chapter CT
DriverRider is offline
post #4 of 12 (permalink) Old 09-04-2019, 06:42 PM Thread Starter
Year: 1984
Make: Honda GL1200I
Model: Interstate
Yeah I'm certain the carbs are getting fuel because the spark plugs are soaked and I can smell it in the exhaust. I'm going to check my compression again. I checked it earlier and all cylinders showed 120 or better but the compression gauge I used wasn't a good fit for the bike so I'll check it again with another gauge that I can rely on.
post #5 of 12 (permalink) Old 09-04-2019, 06:46 PM Thread Starter
Year: 1984
Make: Honda GL1200I
Model: Interstate
Thank you, I'll do a thorough check of all the connections when I get back to the bike on the weekend, it's located in another city for now because I didn't want to ride it home in case I might do some serious damage.
post #6 of 12 (permalink) Old 09-04-2019, 07:00 PM
Model: The best
If fuel is dumping into those cylinders mixture can be too rich to ignite properly which will show as near dead.
Bike...and Dennis likes this.
J.D.
Starter ride
Rupp
Previous rides
Bultaco
Yamaha 360
Yamaha 650
WS Grand Chapter CT
post #7 of 12 (permalink) Old 09-12-2019, 07:40 PM
msgoodwrench's Avatar
Year: 1983
Model: GL1100A
plug wires
One other thing you might check before you start tearing into things too deep; I found on my '83 that very problem. Spark, but not strong spark, causing fouled plug acting like a dead cylinder. What fixed it was taking the plug wire apart from the plug cap. The cap screws onto the wire and that is a missed connection when checking things out. I found that there was corrosion in that joint on my #3 plug. Once that was cleaned up it was good to go! Just something else to check out.
JamesPal likes this.
msgoodwrench is offline
post #8 of 12 (permalink) Old 09-12-2019, 10:35 PM
Average Goldwing Rider
JamesPal's Avatar
Year: 1972, 1981, 1985
Make: CB450, GL1100, GL1200I
I like to do the simple stuff first. Have you tried new plugs? Spark plugs can become gasoline fouled just like being oil fouled. The difference is you can see an oil fouled plug, but spotting a fuel fouled plug is much harder. If the carbs are off try filling the intake track with starting fluid and see if it fires on that cylinder. Just my 2
Jim Palmer
Current rides:
\'85 GL1200I Garage Find
\'81 GL1100 Std
\'72 CB450K5
My \'81 Restoration:
JamesPal is offline
post #9 of 12 (permalink) Old 09-13-2019, 09:01 AM Thread Starter
Year: 1984
Make: Honda GL1200I
Model: Interstate
Yes cylinder 4 is filling with fuel and not firing. I'm going back to the needle and seat because I think the new ones I installed are simply leaking and allowing fuel into the carbs. Sometimes parts you order online are just not up to the job. I have new parts from a trusted supplier here. I'll recheck my floats and basically start from scratch. I had a local mechanic I trust to check the spark level and do a compression test and everything is as it should be except the over rich problem. I'll know tomorrow. Thanks for your input.
post #10 of 12 (permalink) Old 09-13-2019, 09:06 AM Thread Starter
Year: 1984
Make: Honda GL1200I
Model: Interstate
Yeah I did install new plugs and it took about 5 minutes for number 4 to foul. Starting again this weekend. I think I've narrowed down the problem to poor quality replacement parts, I have parts I can trust to install this weekend. Thanks for your input.
