87 GL1200, Engine shut down - Steve Saunders Goldwing Forums
 4Likes
  • 1 Post By earlddavis1
  • 1 Post By redwing52
  • 1 Post By Bike...and Dennis
  • 1 Post By JamesPal
post #1 of 6 (permalink) Old 09-09-2019, 11:15 AM Thread Starter
earlddavis1's Avatar
Year: 1987 and 1989
Model: GL1200 and GL1500 Trike
Thought I would share an experience. I was riding my 87 Aspencade yesterday. We rode up to Mt Rainier here in Washington state. When it came time to leave I had to crank the starter before it fired, it normally doesn't go a full revolution. Then on the way down the engine just shut down. I flipped the kill switch, nothing, then I reached up and turned the ignition off and back on. It fired up and we were riding again. a little later it shut down again, I did the ignition switch thing and it didn't help, I will add that we were coming down off the mountain so it was in gear all the time. It suddenly fired again. It did this about 3 times and then was running fine. I rode until we stopped to eat. When I parked it I opened the tank cover and checked all connections, with the engine running, nothing, wiggled all the wiring I could get hold of, moved the handlebars nothing. We ate and left, went about 12 miles and ir shut down for about 100 feet before I could stop it fired up again went about 3 miles and shut down. This time it stayed off until I could stop. I pushed the starter button nothing. Finally, something to check. I thought the first thing will be the safety switches and since the only thing I was using while all this was going on was the clutch. I pulled back the rubber cover and sure enough one of the wires was falling off the clutch switch I tightened it and slipped it back on, the engine cranked and we rode the rest of the trip without a hitch
AZgl1800 likes this.
earlddavis1 is offline
post #2 of 6 (permalink) Old 09-09-2019, 11:23 AM
The clutch switch would be the reason the starter would not crank but that wire being loose would not shut the engine off. You might still have another issue.
Bike...and Dennis likes this.
redwing52 is offline
post #3 of 6 (permalink) Old 09-09-2019, 11:55 AM
Year: 1985
Model: Interstate
There may have been a ignition switch recall back in the day on those bikes I vaguely remember something like that
Sprocketrocket55 is offline
post #4 of 6 (permalink) Old 09-09-2019, 12:21 PM
Look at the wires on the starter solenoid. They can get crispy and do what you describe.
redwing52 likes this.
post #5 of 6 (permalink) Old 09-09-2019, 10:30 PM
Average Goldwing Rider
JamesPal's Avatar
Year: 1972, 1981, 1985
Make: CB450, GL1100, GL1200I
One more item, the ignition switches can fail. There are kits out there to replace the electrical portion of the switch.
Jim Palmer
Current rides:
\'85 GL1200I Garage Find
\'81 GL1100 Std
\'72 CB450K5
My \'81 Restoration:
JamesPal is offline
post #6 of 6 (permalink) Old 09-10-2019, 02:58 PM
noviwinger's Avatar
Year: 2015
Model: Audio Comfort
I had a problem with my old 86, I was pulling a trailer through KY. suddenly it died and I could restart it but it died again a little ways down the road. Eventually, it would no longer start. I pulled the side cover off and the wires to the starter relay had melted. Fortunately, I had pulled into a Auto Zone and went in and bought some connectors and put them on the wires, after peeling back all the melted casings and connect them backup and I was good to go. It was still running that way for when I sold it about 50,000 miles later
noviwinger is offline
