Carb kit GL1000 - Steve Saunders Goldwing Forums
 6Likes
post #1 of 13 (permalink) Old 09-16-2019, 01:43 AM Thread Starter
Year: 1977
Model: Gl1000
Carb kit GL1000
Howdy guys,
So I just got my 77' Goldwing kinda running after its been sitting since 89. It only runs when given throttle and won't idle under 2300ish rpm and only starts on starter fluid. It sounds good and is super smooth when at 2300, but obviously thats not right. I will be adjusting the valves here shortly and I already changed the timing belt but I think the carbs need some loving.
Any kits you all recommend? The Randakk one looks good but I'm poor and I'm just trying to get the bike running and driving for as cheap as possible. Have you all had any luck with the kits on ebay?
Thanks
StarDiero75 is offline
post #2 of 13 (permalink) Old 09-16-2019, 05:41 AM
Don't waste your money on the cheap kits. You may not need a kit at all, take the carbs out, flip them over and remove the bowls and see how bad they look inside.
post #3 of 13 (permalink) Old 09-16-2019, 08:29 AM
if the parts are not Honda, it is a waste of money.
Been proven over and over...
most likely you just need to boil the carbs in vinegar,
or hopefully you have access to an Ultrasonic Cleaner.... those are terrific.
BadMonk's1200 likes this.
post #4 of 13 (permalink) Old 09-16-2019, 10:32 AM
tlbranth's Avatar
Year: 1999, 1975
Model: GL1500SE GL1000
See if you can borrow Randakk's video from someone. It's good. If you do buy a kit, work nights and get Randakk's. Well worth the money.
DaveO430 likes this.
Terry
Don't own a Vanagon.
Don't work at Boeing.
Life is good.
1970 CB750
1975 GL1000
1999 GL1500 SE
2002 VT750
tlbranth is offline
post #5 of 13 (permalink) Old 09-16-2019, 08:53 PM Thread Starter
Year: 1977
Model: Gl1000
I might just take them out and check the bowls then. I just added some seafoam to the tank got it to where some is sitting in the carbs and now I'm gonna leave it for a few days. Also i found out that my valves are tightened too much. It backfired through the carbs on startup without the choke pulled and starter fluid. I pulled the covers and they were all too tight. So I'll fix that and see how it runs after the valve adjustment and seafoamed carbs
AZgl1800 likes this.
post #6 of 13 (permalink) Old 09-17-2019, 01:23 AM
Year: 2006
Of course the valves need to be adjusted to spec. , BUT when an engine backfires through intake it is an typical sign of running to lean due to carburator problems !
(if the valves has some clearange they shouldnt leak , but as said they should be adjusted to spec )
SMEDEN(=the blacksmith) is online now
post #7 of 13 (permalink) Old 09-18-2019, 01:34 AM Thread Starter
Year: 1977
Model: Gl1000
So I adjusted the valves and have now found out that the carbs definitively need some loving. Randakk kit here I come!
post #8 of 13 (permalink) Old 09-18-2019, 07:04 AM
dingdong's Avatar
Model: 93 Gl1500 / 76 Gl1000
Randakks kit doesn't come with float valves. You need to go to Honda for OEM valves. They are the only ones that are dependable.
Tom
Black 93 1500 Aspy
Yellow 76 1000
Black Cherry 04 Rune Sold
"I've now been in 57 states? I think one left to go?" B. O.
dingdong is offline
post #9 of 13 (permalink) Old 09-18-2019, 12:49 PM
Keihin needles can be gotten here.
http://power-barn.com/keihin-float-n...m-carburetors/
post #10 of 13 (permalink) Old 09-18-2019, 08:02 PM Thread Starter
Year: 1977
Model: Gl1000
But Randakks says to keep the original needle? Should they be swapped out?
