Can't get piston out of slave gl1200 - Steve Saunders Goldwing Forums
 3Likes
post #1 of 11 (permalink) Old 09-21-2019, 10:37 AM Thread Starter
Nochickenwing's Avatar
Year: '81 Frame w/ '84 Motor
Model: Standard
Well, I started repairing my slave this morning but now I'm stuck. I got the slave off but did not think about needing the piston to pop out and I already took the slave off completely. Any ideas on getting the piston to pop out? Any help is appreciated
Nochickenwing is offline
post #2 of 11 (permalink) Old 09-21-2019, 12:22 PM
It aint rocket science
DriverRider's Avatar
Model: The best
A blast of compressed air.
J.D.
Internet myth buster
Starter ride
Rupp
Previous rides
Bultaco
Yamaha 360
Yamaha 650
WS Grand Chapter CT
DriverRider is offline
post #3 of 11 (permalink) Old 09-21-2019, 12:30 PM Thread Starter
Model: Standard
Compressed air sounds good but I don't have access to a compressor ☹️
post #4 of 11 (permalink) Old 09-21-2019, 12:37 PM
Year: 1992
Model: Aspencade 1500
Hook the line from the master back up, and use that to pump it out.
kenneym likes this.
RambozoClown is offline
post #5 of 11 (permalink) Old 09-21-2019, 12:53 PM Thread Starter
Model: Standard
Well...I hooked my line back up from the master and for some reason it came out a smidge but won't budge any further. I'm lost and frustrated
post #6 of 11 (permalink) Old 09-21-2019, 03:17 PM
If you can figure out a way to couple it to a garden hose the water pressure will do the job. Have you tried a bicycle pump? Messy but it should work. Jimmy a way to get a grease fitting on it then use a grease gun. Keep the excess grease and use it for chains or garage doors etc.
redwing52 is offline
post #7 of 11 (permalink) Old 09-21-2019, 03:27 PM Thread Starter
Model: Standard
I wanted to thank everyone for the responses 😁. I found a mechanic shop that was willing to give it a blast of compressed air. She popped right out. I'm about to clean it all up now and put the repair kit in and put everything back together.
AZgl1800 likes this.
post #8 of 11 (permalink) Old 09-21-2019, 03:28 PM Thread Starter
Model: Standard
This site is priceless!!!!😁😁😁😁
post #9 of 11 (permalink) Old 09-21-2019, 04:11 PM
Glad that all the gurus here could help you out.
post #10 of 11 (permalink) Old 09-21-2019, 04:14 PM
Year: 1992
If it didn't pump out with the master, that probably needs a rebuild, too. Generally, if one end is trashed, so is the other.
