Trailer wheel hubs - mounting info needed - Steve Saunders Goldwing Forums
post #1 of 10 (permalink) Old 07-22-2007, 01:15 PM Thread Starter
miles.from.nowhere's Avatar
I'm assembling the trailer I just got off eBay. When I'm mounting the wheel hubs on the axle, how tight should the axle nuts be? My wee mind is telling me to snug them right down then back them off one notch in the crown nut to line up the cotter pin.
Am I out to lunch or is this accurate?
Miles
Double darksiding on my newly triked ride!
Remember, while you are the oldest you have ever been, you are also the youngest you will ever be - and it\'s all running out pretty fast so make the most of what\'s left!
miles.from.nowhere is offline
post #2 of 10 (permalink) Old 07-22-2007, 01:36 PM
Geordiemuppet's Avatar
Year: 1975, 2015
Model: GL1000, GL1800
GENTLY tighten to where the bearing starts to feel tight (spinning it all the time)and then back off one flat of the nut. This is assuming you have cleaned and repacked the bearings.
Paul
2015 GL1800 40th Anniversary Ladybug.
1975 GL1000K0
1992 ST1100M
Confusion will be my Epitaph....
Geordiemuppet is offline
post #3 of 10 (permalink) Old 07-22-2007, 01:39 PM Thread Starter
Thanks Geordiemuppet The bearings came packed with new grease. The hubs have a grease nipple on the back so I'll add more grease once the hubs are mounted up.
Miles
post #4 of 10 (permalink) Old 07-22-2007, 07:06 PM
Just one of the guys
DougW's Avatar
The easiest test I use is with the weight off the trailer grab the front and rear of the tire. Try to rock it back and forth. It should be tight enough to not move laterally yet loose enough to turn freely.
Doug
DougW is online now
post #5 of 10 (permalink) Old 07-22-2007, 07:10 PM Thread Starter
Thanks Doug - that's pretty much where it's at - should be good to go!
Miles
post #6 of 10 (permalink) Old 07-22-2007, 08:23 PM
Token Canuk
96aspencade's Avatar
Model: 1996 SE
Justa thought, but the caps that fit in the hubs with a grease fitting pointing out are cheap & handy, easier than crawling under to get at the nipple on the back & supply an extra amount of grease for the long trips.Look for the ones with a bleeder hole to avoid excess pressure on the seal's
Retired Paramedic - 35 yrs
DD # 1138
30,000 miles - Formosa,
'96 GL 1500 SE - 260,k km
'83 Shadow 500
'70 Kawasaki KE-125
'?? Suzuki 80
96aspencade is offline
post #7 of 10 (permalink) Old 07-22-2007, 08:50 PM
DougW's Avatar
Glad to be of help, now just make sure to check them when stopping for breaks. They will get warm but you should be able to hold your hand on them with no discomfort, it they get warmer than that they are tad too tight.
Doug
DougW is online now
post #8 of 10 (permalink) Old 07-22-2007, 09:00 PM Thread Starter
96aspy - I went to grease it up tonight and as I was struggling to get at the nipples I thought to myself - you need to get bearing buddies at Canuck Tire on the way home tomorrow. And so I shall. Didn't know about the bleeder hole so I'll look for that feature.
DougW - Pee breaks and gas stops should always include a walk-around and the trailer hubs will get checked at that time. Thanks again.
Miles
post #9 of 10 (permalink) Old 07-22-2007, 11:07 PM
I don't like Bearing Buddies on trailers other than boat trailers that go into salt water. They have a tendency to push the grease seals out of the hubs. You really don't need to grease trailer bearings very often. Cars with rear drive usually go 25,000 miles and several years between repacking of the front wheel bearings and they rarely fail. A bike trailer (though the wheels spin a bit faster) isn't carrying near the weight or side loads and doesn't usually go that many miles per year. Once every couple or three years should be more than sufficient.
With new bearings or bearings being reinstalled I always check the wheels after a 100 miles or so. They can loosen up on the inital run. Mainly just lift the wheel off the ground and see if there's any play. I also check the trailer hubs for heat after the first 100 miles and once a day after that. A wheel with a warmer hub than it's mate or a hub that's hot to the touch has a problem. One that's just a bit warm doesn't.
Be cautious if you use your hand to test the hub for heat as I do, if there's a bad bearing that hub can be very hot!
post #10 of 10 (permalink) Old 07-23-2007, 05:53 AM
Token Canuk
Model: 1996 SE
The Bearing Buddies with the bleeder hole have it so they will not hurt the seals, any excess pressure is released without damage. when doing 7,000 - 10,000 mile trips the extra supply of grease is a nice, cheapadd on.
DD # 1138
'83 Shadow 500
'70 Kawasaki KE-125
'?? Suzuki 80
info needed siebo Goldwing Technical Forum 2 11-15-2009 07:04 PM
info needed siebo Goldwing Technical Forum 8 08-11-2009 05:37 PM
mounting trailer hitch HuskerDJ Goldwing Technical Forum 14 08-06-2008 08:32 PM
INFO NEEDED ?????? rolly Goldwing Technical Forum 2 09-28-2007 09:12 PM
12V accessory plug mounting ideas needed Sandy Eggo General Motorcycle Discussion Forum 16 09-02-2007 10:48 PM
