stumbled on a neat trick today... - Steve Saunders Goldwing Forums
post #1 of 21 (permalink) Old 08-05-2012, 03:24 PM Thread Starter
Still a winger at heart.
UbarW's Avatar
Model: Sure wish I could ride...
Send a message via Yahoo to UbarW
I have two vehicles that have nasty belt squeal. All the belts are newish.
I put a bit of water based valve grinding compound on the belt and the pulleys. Run it and it takes the glaze off the belts, pulleys, and when its dry, it just flings off.
No more squeal.
Neat...
Proud Member of the Patriot Guard Riders-Id: 79170
Panel 16W - Line 33
UbarW is offline
post #2 of 21 (permalink) Old 08-05-2012, 05:26 PM
blackknytecnc's Avatar
Year: 1985
Model: 1985 GL1200 LTD
That's pretty cool, I was always told to use some bee's wax, but I don't have any of that laying around... now grinding compound, that I have... don't ask
blackknytecnc is offline
post #3 of 21 (permalink) Old 08-05-2012, 06:32 PM
Disfunctional Nimatode
Dancinbear's Avatar
A touch of bar soap works good too!
Don't want a deal with alot of flibiddy-flab or mumbo-jumbo...........
2003 GL1800 Illusion Blue
Dancinbear is offline
post #4 of 21 (permalink) Old 08-05-2012, 07:17 PM
GERIATRIC MEMBER
Redwing's Avatar
Model: Neighbours 1800
[align=center][/align]
[align=center]So does WD40.......[/align]
"Redwing"
Redwing is offline
post #5 of 21 (permalink) Old 08-05-2012, 07:33 PM Thread Starter
UbarW's Avatar
not sure if I like the idea of wd on the belts and such... you sure redwing?
Panel 16W - Line 33
UbarW is offline
post #6 of 21 (permalink) Old 08-06-2012, 08:56 AM
redbaron's Avatar
Model: GL-1500
At one time I had this LONG list of things that WD-40 could be and had been used on, and I believe spaying it on squeking belts was one of its uses????...Seems that these "snake belts" get dried out and get slick, a small shot of WD-40 "limbers" them up some....Of course theres always take a wrench, tighten that belt up and give it a shot of "Belt Dressing"....My Jeep was going through belts like crazy , until I finally broke down bouight the high dollar belt....No more El Cheapo belts...
Now here's something scarry!!!!...Last year my neighbor and I were talking, my Jeep was running, then all of the sudden it was like "POW" and the engine died????...Looked under the hood that belt had broken, and it was wrapped around the lower pulley...No problem!!! WRONG!!!!...That belt went behind that lower pulley and actually went inside the crank seal!!!...I had to pull the radiator, sheilds, lower pulley and timing cover to get all of the pieces out!!!!..Good Thing???..I noticed that the timing chain tenisioner was broken, and the timing chain was loose...That El Cheapo belt cost me almost $200.00 when it was over,two week of using the wifes car to get to work, and lets not talk about the cuts scraps and band aids I wore for weeks after....So check them belts every so often as to not so much the top side, but the grooved side for cracks, if it has cracks in it, theres your first sign to change it out!!!!!
Honorary member Wild Rhinos
redbaron is offline
post #7 of 21 (permalink) Old 08-06-2012, 09:32 AM
Senior Mem & Story Teller
monkeytrucker's Avatar
Year: 2010
Make: honda
Model: 2010 GL 1800 comfort (buried after fire)
We used to use corn starch on belts on farm equipment to make the belts stop slipping due to becoming slick.
Life is a collection of stories we old people tell and hope a few will listen and carry them into the future.
There is a story to everything we have, everyone we have met and everything we have done or we will do or dream about doing.
We sometimes ride to forget, but hopefully we never forget to ride.
Illinois Patriot Guard
Honda SL 175
Honda XL 350
Honda CB 750 X 2
Kawasaki 250
Honda GL 1200 Interstate
Honda GL 1800 (my last and one of the last made in the USA)
monkeytrucker is offline
post #8 of 21 (permalink) Old 08-06-2012, 10:06 AM
FM
FM's Avatar
Model: 91-I
I use 100 - 120 grit sandpaper on the glazes pulleys. Not deep heavy marks, just enough to give a little TOOTH so the belt has something to grab to.
IF you're not inclined to skuff the pulleys then use that paper on the belts to remove the glaze.
Motor off, of course.
Drag the paper from center to outside. That's 90 degrees to the direction of the belt.
FM is offline
post #9 of 21 (permalink) Old 08-06-2012, 05:22 PM
GERIATRIC MEMBER
Redwing's Avatar
[align=center]
Yeah my neighbour uses WD40 on almost everything.... I see that cowboy redbaronfrom Texas agrees, so it must be ok UBarW.....[/align]
"Redwing"
Redwing is offline
post #10 of 21 (permalink) Old 08-06-2012, 05:38 PM
FM
FM's Avatar
Model: 91-I
Redwing wrote:
[align=center]Yeah my neighbour uses WD40 on almost everything.... I see that cowboy redbaronfrom Texas agrees, so it must be ok UBarW.....
[/align]
I never knew WD40 actually dried out to a slightly tacky-sticky mess until I used it on my car locks. A couple weeks later those locks got harder to turn. Being the main door to get into I had to disassembled the drivers door lock ONLY to find WD40 gummed up the locks pins.
GOOD STUFF WD40... when & where you know how to use it.
FM is offline
Stumbled across these poppy fields agnogel Miscellaneous Forum 16 06-08-2011 10:12 PM
Met a neat older gentleman today hockeydad33 General Motorcycle Discussion Forum 16 02-23-2011 07:07 PM
Stumbled across it manxmann New Members Introduction Forum 16 01-02-2011 08:00 PM
Stumbled onto this site Bradbury New Members Introduction Forum 4 09-07-2008 01:42 AM
Stumbled onto a neat cold weather riding trick for a 1500 AZgl1800 General Motorcycle Discussion Forum 5 02-11-2007 08:58 AM
