1998 Chevy Lumina error code - Steve Saunders Goldwing Forums
post #1 of 10 (permalink) Old 11-10-2012, 04:00 AM Thread Starter
9394SEs's Avatar
Year: 94SE & 93SE w/sidecar
Model: 2 SEs
I am trying to get this car started after a year or so of sitting idle. I got error codes of "P0107" and "P0122". The first means MAP/BORO circuit low input, second one Throttle Position Sensor A circuit low input. Question is where do I go from here? Could these be mice teeth related?
"The simplest toy, one which even the youngest child can operate, is called a grandparent." Author unknown
"Friends don't let friends change V-6s" I said that
9394SEs is offline
post #2 of 10 (permalink) Old 11-10-2012, 05:46 AM
seabee's Avatar
Yes. Check the easy stuff first. Mice love to chew on insulation and wire. Follow the wires to make sure nothing is chewed thru. These sensors are usually two wire circuits and if you lose one it won't get the proper signal.
Paul
CE1 Navy Seabees/RET
1981 to 2002
ASE Mechanic
1985 Goldwing Aspencade-114,000 miles - Best bike ever
Previous Bikes:
1977 Kawasaki KZ400 - My cost me nothin\' bike
1978 Suzuki GSXr750 - Craziest bike *wicked fast
1980 Kawasaki GPZ400 - Funnest bike
1975 Honda CB360T - 1st bike
seabee is offline
post #3 of 10 (permalink) Old 11-10-2012, 09:38 AM
Model: '07 GL1800
I wouldn't think these things are bad from just sitting. A corroded connection maybe but the parts should not go bad. Also they shouldn't stop the car from running. MAP is manifold air pressure. A gasoline engine creates a vacuum. With the engine not running it is at zero and when running it will go to a negative. TPS is just that, the computer want's to where the gas pedal is. Is is in an idle position or is it asking for more power/acceleration? I think if you just go through the basics, air-fuel-fire, you'll get it running. I'd start with air follow the air intake and make sure there are no obstructions and that the throttle body is opening. Then fuel. When you turn the key on are you hearing the fuel pump build pressure? When you pull a plug can you smell fuel? When you crank it over is that plug firing? If it does fire up and run but runs crappy keep it going for a while. It will take it a little time for the computer to relearn everything. (If the battery has been dead awhile the computer loses it's memory. I'd try to get the fuel out and get some fresh stuff in. I'm sure you've read all the E-10 posts here and elsewhere. I wouldn't put any additives in the new fuel till it's running and drivable.
donno is offline
post #4 of 10 (permalink) Old 11-10-2012, 12:27 PM
GERIATRIC MEMBER
Redwing's Avatar
Model: Neighbours 1800
Post
Post this over on the Tech Forum it will be seen by all our Tech experts
"Redwing"
Redwing is offline
post #5 of 10 (permalink) Old 11-10-2012, 06:37 PM
Then it would get moved back here, the tech forum is for goldwings only.
I agree with seabee, check for chewed wiring.
post #6 of 10 (permalink) Old 11-11-2012, 04:24 AM Thread Starter
9394SEs's Avatar
Model: 2 SEs
Here's what I've done. Charged the batt then jumped it for extra boost and gave it a short blast of starter fluid...no start not even a pop. I know this motor is on it's last leg thanks to the infamous GM V-6 intake gasket failures and the stepdaughter being to lazy to check the oil. The car is from Florida so it's still in good shape chassis/body wise. It might be a good car for the stepson to start driving with but it may need a used motor.
I got jumped on the GW board for posting a toyota question so that's why I posted under miscellaneous boards. Probably won't be seen by as many techies but I am going by board rules....Tia, Rick
9394SEs is offline
post #7 of 10 (permalink) Old 11-11-2012, 08:11 AM
GERIATRIC MEMBER
Redwing's Avatar
Who told you that????..... Thats news to me...
"Redwing"
Redwing is offline
post #8 of 10 (permalink) Old 11-11-2012, 11:40 AM
blackknytecnc's Avatar
Year: 1985
Model: 1985 GL1200 LTD
Yeah, happens every time
Have you checked the connections on the throttle body? Have you checked to see if the throttle blade is closing all the way? Have you replaced the intake gaskets? Last, have you run a compression test yet?
If it's got good compression, you still have some good miles out of it as long you take care of the intake gaskets. At this point, you have two specific failure points, so I would start at the MAP and TPS and check them as well as everything attached to them, then start following the harness back until you find the problem. Sounds to me like a relatively simple fix. Even IF both sensors are bad and you opt for new instead of used, it's cheaper than a used motor.
blackknytecnc is offline
post #9 of 10 (permalink) Old 11-13-2012, 04:09 AM Thread Starter
9394SEs's Avatar
Model: 2 SEs
This car has been little more than a PIMA since day one. First thing I do with electrical problems is unplug then replug all available connectors with a corrosion check thrown in for good measure. What I need is what to check for after the OBDII codes are read. Volts, ohms, watts, high/low blood sugar. Without buying a factory electrical manual is there a website or someone that can give me a clue as to how to trouble shoot these codes and narrow down my search time? Rick.
9394SEs is offline
post #10 of 10 (permalink) Old 11-13-2012, 06:44 AM
You can purchase a PDF factory manual here for very reasonable cost.
I got one for my Dodge diesel truck for ~ $10.00
http://www.tradebit.com/filesharing....evrolet+lumina
1998 GL1500 SE with 1998 Kwik Kamp trailer Wingmaster Shamus For Sale/Wanted Forum 65 10-04-2012 06:54 PM
GL1200Sei De-error code. troy enochs Goldwing Technical Forum 10 07-29-2012 06:24 AM
2001 Golwing 1800 F1 Error code 19 basilmulkey Goldwing Technical Forum 8 08-19-2011 12:10 AM
chevy fans keithg64 Miscellaneous Forum 1 06-09-2009 09:52 PM
chevy engine jermar Miscellaneous Forum 8 01-29-2007 11:32 PM
