What is this wire for? - 2001 Suburban accessory block - Steve Saunders Goldwing Forums
post #1 of 2 (permalink) Old 11-17-2017, 01:39 PM Thread Starter
This block is located adjacent to the foot operated parking brake.
I had to pull the carpet back to get to it, and that is when I found the Orange wire.
There is an Orange wire with a molded block connector that just falls over the edge of the block, is wrapped with loose vinyl tape and connects to a wire harness that goes from way up high, to the door sill and back to ????
I found it when I was trying to locate where to plug in the Plug-N-Play Teksonsha Electric Trailer Brake controller.
post #2 of 2 (permalink) Old 11-17-2017, 02:50 PM
Dome light.
How do you wire a switched accessory?. wildfire Goldwing Technical Forum 5 05-22-2014 06:28 PM
GL1500 Hot wire for Accessory mode Ojai Roy Goldwing Technical Forum 21 06-09-2012 11:38 AM
Hot wire for Accessory mode, GL1500 Ojai Roy Goldwing Technical Forum 2 05-26-2012 09:38 PM
Power Fuse Block GL1500...which wire to use for relay? JackfromCT Goldwing Technical Forum 5 08-23-2010 08:14 PM
Trouble with stator wire block removal old sarge Goldwing Technical Forum 6 01-06-2007 10:31 PM
