Memories - Steve Saunders Goldwing Forums
 7Likes
  • 3 Post By AZgl1800
  • 1 Post By Sticks
  • 1 Post By Peter Goldwing
  • 1 Post By LarryC
  • 1 Post By WingRider101+
post #1 of 6 (permalink) Old 12-17-2017, 03:52 PM Thread Starter
Cool Memories
I was answering a post in another thread and it brought up memories of decades past.
Mardonna's home of birth, and where all of her family are/were, is Bluffton, Indiana.
One year, she wanted to go home, but I was on a construction project and could not get off work.... I had her drive our 1974 Suburban because of its' safety and reliability.
It had a 454 engine which liked to sip on engine oil.... a leak somewhere?? never bothered me, I just looked at it every 3rd tank of gas or so.
but, with her traveling, I just said " when buying gas, look at the engine oil, it will probably want some before you get home."
Well, I thought she knew the difference between the Transmission dip stick and the engine dip stick
uh, no it seems.... she stopped at a gas station up toward Illinois somewhere, and checked the oil... It was "low again", and she put in another quart of oil.
well, a guy at the place walked out and asked why she was putting in more oil, when it was already puking oil out on the ground?? She explained what I told her, and showed him on the DIP STICK how it was still low...
Bless his heart, he gently showed her the words on the cap, the yellow one is for the Trany ma'am....
then he had her look way over the fender "down there" at the RED cap and it is labeled OIL.....
He put the Suburban on a lift, drained out several gallons of oil, poured in 5 quarts of new oil, and sent her on her way.....
I can't remember if he even charged her doing that.... he was so tickled at the time.
post #2 of 6 (permalink) Old 12-17-2017, 05:01 PM
Sticks's Avatar
Year: 1995
Model: 1995 GL1500 SE
How poor life would be without good memories. Thanks for sharing, I enjoyed that.
Peter Goldwing likes this.
Forgive others. Not because they deserve forgiveness, but because you deserve peace.
If your not willing to forgive others, how can you expect God to forgive you.
Sticks is offline
post #3 of 6 (permalink) Old 12-17-2017, 05:19 PM
Peter Goldwing's Avatar
Year: 2008
Model: GL 1800
John, your memories reminds me about my memories. Been married for about one year and I thought it is a good idea to show Letizia how to add oil to a car.
She came out and attentively was watching me.
Back then the oil came in a cardboard like can with a metallic lid. They made an opener and pourer for it but i did not have one. i used the screwdriver to poke a few holes.
I hit the can with the screwdriver and poked a hole in it. Then trying to poke more holes for the air to be sucked in while pouring I hit the can again. The oil splashed out thru the first hole on my face. Undeterred I hit it again and i got more oil in my face. Both of us stated to laugh like nuts. I hit it a few more times and still laughing I told her " Thats the way you do it"
Part deux.
I was changing the oil in my work van. I drained it in an oil pan, pulled the pan out for under the van and started to pour oil into it. After the second bottle a long line of fresh oil was approaching my feet. You guessed it. I forgot to put the plug back in.
WingRider101+ likes this.
Follow me on the spot
Peter Goldwing is online now
post #4 of 6 (permalink) Old 12-17-2017, 07:41 PM Thread Starter
2 years ago getting ready to go to a rally up in WVA where Jobe05 was hosting it, I did the oil change, put the plug in by hand, got up to find the wrench to tighten it....
Arrived there 3 days later and walked out the next morning to a small puddle of oil under the bike.
Poured in about 3/4 quart to get it back to full.
Yup, plug was just barely hand tight.
post #5 of 6 (permalink) Old 02-21-2018, 05:32 PM
LarryC's Avatar
I was riding my XS750 Yamaha to work one morning. As I turned on hwy 125 towards Bluejacket, I felt my right leg was getting really warm. Looked down and it was covered with oil! I stopped, and, as luck would have it, my oil filler cap was still sitting on the engine. I screwed it back in and stopped in Bluejacket. It took 2 quarts of oil to bring it up to full. I had added some before leaving for work and forgot to put the cap back on. Been real careful with that since!
AZgl1800 likes this.
Larry
84 Aspencade
79 GL1000 with VW carb
LarryC is offline
post #6 of 6 (permalink) Old 02-22-2018, 12:21 PM
WingRider101+'s Avatar
Year: 1998
Model: GL 1500 SE
Just out of high school I had a 1982 Firebird with the 2.5L "Iron Duke" and a 4 speed trans. At 160K + miles that little 4 cylinder hauling around that big car was tired out. (never mind how a 19 y/o drove a flashy looking stick shift). I bought new pistons and rings - gasket set and seals, pulled the motor on Saturday morning and started it back up to drive it to church Sunday morning.. Didn't have a clue back then that the cylinders would be out of round. So essentially what I had done was put round pistons & rings in oval cylinders. From that day on I was "That Guy" with the constant cloud of smoke behind me!
We joked that I had to "fill the oil and check the gas"
LarryC likes this.
I drive way to fast to worry about my cholesterol
Last Saturday I planned on doing nothing all day, and by noon, I was half way done!
WingRider101+ is offline
  Steve Saunders Goldwing Forums > Off Topic Section > Miscellaneous Forum
Memories AZgl1800 General Motorcycle Discussion Forum 7 06-07-2012 12:09 AM
A veteran's memories TominDallas Miscellaneous Forum 11 01-18-2012 11:51 AM
Memories are made of this clouddragon9 Miscellaneous Forum 3 06-23-2011 10:05 AM
Memories Macabre Character Fun Forum 9 08-03-2010 11:07 PM
MEMORIES teacher Fun Forum 3 09-24-2006 12:57 AM
