The Idling Question - Page 2 - Steve Saunders Goldwing Forums
 3Likes
post #11 of 20 (permalink) Old 07-01-2018, 05:30 AM
post #12 of 20 (permalink) Old 07-01-2018, 08:00 AM
Year: 1986
Make: honda
Model: gl1200A
dave0430, i think you just won a whole raisin pie!
claydbal is offline
post #13 of 20 (permalink) Old 07-01-2018, 08:36 AM Thread Starter
Dave,
I had found that earlier in my searches as well.
1st off, my Cruise is on the Stalk on the left side of the Steering Wheel, but I tried it anyway. Does not work.
then I saw a note it is only on the 2008 year model trucks?
I see in your note it says the "parking brake must be applied". that note was not in my link, I will go try it again to see if that works for me.
I've already ordered up the Vernier Cable you gave me the link for, so if the CC system won't work for me, the cable darn sure will.
One ?? though, won't I have to provide a "Square box coupler" over the CC linkage pivot? seems that I remember the truck I used to drive had a rectangular "box" built around the CC pivot so that the cable does not interfere with the throttle/CC functions.
post #14 of 20 (permalink) Old 07-01-2018, 10:19 AM
You will have to make some kind of slip joint so the cable won't interfere.
post #15 of 20 (permalink) Old 07-01-2018, 03:49 PM
big PIA
MysticFour's Avatar
I was in garage this afternoon but couldn't find that cable, not sure if I let someone else take it or if 1 of my brothers grabbed it. I don't remember getting it down but could not locate it, sorry.
AZgl1800 likes this.
MysticFour is offline
post #16 of 20 (permalink) Old 07-01-2018, 07:11 PM
pidjones's Avatar
Model: '06 GL1800, '78 GL1000 with '75 motor
Using a beaded chain as you coupler might help remove CC interference.
"Love 'em all... Let God sort 'em out!"
'52 wife - '69 daughter - '83 daughter
ex '86 SE-i
ex '77 GL1000
pidjones is offline
post #17 of 20 (permalink) Old 07-01-2018, 09:07 PM
OldNewbie's Avatar
Year: 2003
Make: GL1800
Model: Wing
I'd be a +1 for mounting an electric fan to assist cooling. switch it on when needed.
It's very difficult to increase the idle "just a bit" and not have it start to increase more than wished for. try and hold your foot on gas pedal and maintain 1100 without variance to test sensitivity.
the cruise trick was only on diesels, btw
OldNewbie is offline
post #18 of 20 (permalink) Old 07-01-2018, 10:51 PM Thread Starter
it does not need an electric fan. the fan it has roars like a Freight Train when the thermo-coupler engages it... and the air coming out behind it is very strong.
Twice, I got it too hot, gauge up almost at the Red Line.
Once I left it idling too long keeping the dogs cool: raised idle speed to 1500 and the fan started roaring and the temp gauge dropped in about 1 minute, in about 3 minutes it was down to normal again.
2nd time, I got to pushing it too hard, pushing 68 mph instead of 55 mph, against a headwind. Temp redlined and when I saw it, turned off the a/c and dropped the speed back to 50 mph.... in 2 minutes flat the gauge was back to normal.
Chain Beads: Now that is a Damn Good idea!
as for the idle speed, I can slowly press on the throttle and the RPMs will follow very good.
I can hold 1500 RPM constantly and it does not try to hunt.
have a lot of confidence the vernier cable is just the thing I need.
and that beaded chain? problem solved.
post #19 of 20 (permalink) Old 07-05-2018, 11:38 AM Thread Starter
The vernier cable arrived a few minutes ago.
Looks like a premium product to me.
Wind it out to increase speed gently....
Push the big Red Button and snap! it goes back to low idle.
post #20 of 20 (permalink) Old 07-05-2018, 12:26 PM
big PIA
MysticFour's Avatar
That looks exactly like the 1I had in my garage at 1 time
anyone have audio of a smooth idling gl1100? atowley Goldwing Technical Forum 12 01-31-2008 01:32 PM
I lost all power when bike was idling. prizmatik Goldwing Technical Forum 6 03-15-2007 02:00 AM
Back firing when idling down and poor fuel mileage happycamper Goldwing Technical Forum 17 05-04-2006 05:25 PM
Recap of Carb Idling gb45 Goldwing Technical Forum 5 06-29-2005 02:26 PM
Carbs/Idling gb45 Goldwing Technical Forum 8 06-28-2005 12:08 PM
