Internet Service, or the lack of it - Page 2 - Steve Saunders Goldwing Forums
 5Likes
post #11 of 49 (permalink) Old 11-15-2018, 09:59 AM Thread Starter
as the Sat is way the gawd up there, even at the speed of light, it takes a while because that trip has to make it twice, "going up and down" is a trip, and backing up for the reply and back down for the 2nd half of the trip. 4 trips to the moon and back for each ping.
[email protected] ~ $ ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=119 time=637 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=119 time=632 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=119 time=603 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=119 time=637 ms
64 bytes from 8.8.8.8: icmp_seq=5 ttl=119 time=648 ms
64 bytes from 8.8.8.8: icmp_seq=6 ttl=119 time=677 ms
^C
--- 8.8.8.8 ping statistics ---
7 packets transmitted, 6 received, 14% packet loss, time 6000ms
rtt min/avg/max/mdev = 603.444/639.568/677.852/22.041 ms
ping 35.201.111.149
PING 35.201.111.149 (35.201.111.149) 56(84) bytes of data.
64 bytes from 35.201.111.149: icmp_seq=1 ttl=53 time=669 ms
64 bytes from 35.201.111.149: icmp_seq=2 ttl=53 time=658 ms
64 bytes from 35.201.111.149: icmp_seq=3 ttl=53 time=658 ms
64 bytes from 35.201.111.149: icmp_seq=4 ttl=53 time=662 ms
64 bytes from 35.201.111.149: icmp_seq=5 ttl=53 time=857 ms
64 bytes from 35.201.111.149: icmp_seq=6 ttl=53 time=620 ms
64 bytes from 35.201.111.149: icmp_seq=7 ttl=53 time=660 ms
64 bytes from 35.201.111.149: icmp_seq=8 ttl=53 time=659 ms
64 bytes from 35.201.111.149: icmp_seq=9 ttl=53 time=662 ms
^C
--- 35.201.111.149 ping statistics ---
10 packets transmitted, 9 received, 10% packet loss, time 9000ms
rtt min/avg/max/mdev = 620.337/678.865/857.195/64.434 ms
post #12 of 49 (permalink) Old 11-15-2018, 10:26 AM Thread Starter
Here are 4 test results, most recent is on top of list.
the worst times were right after it was turned on for me, and the rep had to do some adjusting to the Modem parameters from his Maintenance Utility.... that seemed to help..
the Upload is capping out at 1.0 Mbps and I am not happy about that.....
he claims that will get better with a new modem that is not "capped out"....
he has not arrived yet today but it is only 10:30 a.m. and he did not get off the airplane last night from Denver until 12:30 a.m. so suspect he is snoozing in, plus catching up on work details....
post #13 of 49 (permalink) Old 11-15-2018, 04:39 PM
DenverWinger's Avatar
Understood the round trips to the bird and back, the latency is actually better than I was guessing it might be....
1972 CL-350 (1980-1988) sold
1977 GL1000 (2002-2006) sold
1993 GL1500 Aspencade (2017-)
1983 Trav-Lite Camper (2010-)
DenverWinger is offline
post #14 of 49 (permalink) Old 11-16-2018, 07:26 PM
Magic Moderator
trike lady's Avatar
Hope the satellite system is working better today and they brought you the modem that isn't restricted.
Retired trike builder.
trike lady is offline
post #15 of 49 (permalink) Old 11-16-2018, 10:16 PM Thread Starter
the new modem is doing fine, one thing we have noticed with ViaSat is that the down time so far, has been zero up until about an hour ago. For some reason, it rebooted, and that takes a few minutes for it sync back up. Called the rep but he was out and about and could not look at it.
post #16 of 49 (permalink) Old 11-16-2018, 10:32 PM
Magic Moderator
trike lady's Avatar
I ran the speed test and as usual it failed, here are the numbers: 1.24Mbps download, 1.13 Mbps upload and 19ms latency. It mentioned I had very slow internet.
post #17 of 49 (permalink) Old 11-17-2018, 10:39 AM Thread Starter
Val have you tried the Google Speed Test. use google to search for the words google speed test if the forum don't scramble it this is the link https://www.google.com/search?q=goog...firefox-b-1-ab this is a speed test you can run in Terminal mode wget -O - https://raw.githubusercontent.com/si...r/speedtest.py | python
post #18 of 49 (permalink) Old 11-17-2018, 06:14 PM
Magic Moderator
trike lady's Avatar
The Google speed test turned out the same as last night and its still slow as molasses in January.
I gave that other link a try and it sent back, bad request. I may have done something wrong.
Hopefully the Dell will be running Windows7 when the recovery/reinstall media arrives.
post #19 of 49 (permalink) Old 11-17-2018, 10:30 PM Thread Starter
the link in Terminal require Python 3, and if you have one of the slimmed down Linux versions, it is not included.
go to Software Manager and type 'python' and see what shows up.
post #20 of 49 (permalink) Old 11-18-2018, 12:47 AM
Magic Moderator
trike lady's Avatar
Python3 has a green check mark next to it. it also lists a lot of other things with 'Python3' in the title on software manager. I'm not sure what Peppermint9 has. I have to admit since I gave the Dell more RAM, Peppermint9 flies even with the slow @$$ internet speed.
AZgl1800 likes this.
Internet Service, or the Lack of It AZgl1800 General Motorcycle Discussion Forum 12 12-14-2017 07:02 PM
Internet Service - or the lack of it AZgl1800 General Motorcycle Discussion Forum 25 03-14-2016 09:10 PM
Brakes Or Lack There Of Kyle Goldwing Technical Forum 7 04-18-2006 05:23 PM
Fuel Pump Capacity 1984 GL1200 Interstate, lack of power eyeu81 Goldwing Technical Forum 9 09-11-2005 04:41 PM
