Houston, we have a problem or two... - Page 8 - Steve Saunders Goldwing Forums
 14Likes
post #71 of 82 (permalink) Old 02-24-2019, 07:29 AM
DenverWinger's Avatar
I think the 5/8" sheet would be MORE than 1.25 the weight of 1/2", because Sheetrock is layered, the outer layers (maybe 1/8" total?) being less dense stuff. With 5/8" Sheetrock you are adding ALL of the additional 1/8" to the dense core, outer less dense layers remain the same, not increasing by 1.25.
AZgl1800 likes this.
1972 CL-350 (1980-1988) sold
1977 GL1000 (2002-2006) sold
1993 GL1500 Aspencade (2017-)
1983 Trav-Lite Camper (2010-)
DenverWinger is online now
post #72 of 82 (permalink) Old 02-24-2019, 09:46 AM
Year: 2008
Doing a Google search I found that a 4X8X1/2 calculates to 51.2 lbs/sheet. The 5/8 calculates to 70.4. 1.25 X 51.2 = 64 so, 5/8 is much heaver than 25% more. Looking at a 12 ft sheet of 1/2 the weight would be 50% greater or 51.2 + [.50(51.2)] = 76.8lbs. For a 5/8 that comes to 105.6lbs or a net weight increase of 28.8 lbs. He would be charging $5.00 extra to move and install an additional 30 lbs or so to the 75 lbs he has to pick up now. Pay the man, he will earn it.
Charlie
flylow is offline
post #73 of 82 (permalink) Old 02-24-2019, 03:07 PM
the man who can install 8x12 sheetrock, is equipped to put it up...
he has the supporting tools, he is worth is salt.
post #74 of 82 (permalink) Old 02-24-2019, 04:40 PM Thread Starter
Peter Goldwing's Avatar
Year: 2008
Model: GL 1800
We all make rookie mistakes.
Here's mine. I'm going to put 4 LED lights over the sofit so I asked the sheerocker to put in that piece early so I can cut the holes. ( no housing needed for the light). I measured from an end and computed so the lights will be equidistant.
They are not.
The mistake was that I measured on the edge close to me not on center line.
I had to remove the piece and put another one in its place. Looking much better
Follow me on the spot
Peter Goldwing is online now
post #75 of 82 (permalink) Old 02-24-2019, 06:06 PM
True, I had forgotten over the last 44 years. 5/8 is fireguard and is denser than regular 1/2" SHEETROCK.
post #76 of 82 (permalink) Old 02-25-2019, 04:18 AM
Monkey with a Football
Rudy's Avatar
They built 23 wood framed 3 story condos behind us on 2 acres of land and fireguard is all they used between the units for the firewalls.
No escape from the rooftop decks unless you repel down.
Fricking places are built like burning man. They are wood and sheetrock chimneys. But what do you expect for $500k and up?
Rudy
wasn't too much fun”
Rudy is offline
post #77 of 82 (permalink) Old 02-25-2019, 06:26 AM
.... And floor joists that used to be a 2x8 solid piece of wood are now a long narrow strip of OSB with 2x2 edges! Cheap! And they want $500k for these things?
post #78 of 82 (permalink) Old 02-25-2019, 07:19 AM
Rudy's Avatar
Exactly about the floor joists.
$500k and up. The ones with the rooftop decks are like $650-700k
Particleboard palaces. Then the suckers who bought them are the Condo Queens of the neighborhood, don't bother to mingle or even acknowledge the natives.
Works for me as long as they stay the 12 ft excepted easement from the edge of my place.
A 3 story fire can't jump 12 ft...right?
The lot is so tight that for the 23 condos, there is a total of ONE guest parking spot and resident's usually snatch that and ONE 30 x 50 green space for all the resident dogs to use.
Of course the Queens think our streets and yards are for their convenience too.
Can't wait for the breakdown of society.
Rudy
Rudy is offline
post #79 of 82 (permalink) Old 02-25-2019, 11:21 AM
If they can find people to pay that more power to them. It's like almost anything, price has nothing to do with cost.
post #80 of 82 (permalink) Old 03-28-2019, 05:03 AM Thread Starter
Year: 2008
Model: GL 1800
I worked on installing sprinklers for the new house. 6 zones about 40 sprinkler heads.
Even thou I rented a trencher it was very hard work.
Here is a few questions that I have in mind.
Suppose you have a pipe full of water going around the world, over mountains and valleys.. It ends where it starts and you keep both ends at the same elevation. will the pipe leak water out?
Second question :
The pipe is enclosed at both ends and you apply pressure at one end, how long will it take for the pressure to reach the other end?
Third question:
If you apply a steady pressure at one end, lets say 100Lb/ square inch and the pipe has a leak midway, is the pressure at the end the same or smaller than 100lb?
Houston, we have a problem logtech Miscellaneous Forum 4 03-25-2011 08:41 PM
We did it! We did it! We did it! Cousin Jack General Motorcycle Discussion Forum 23 06-30-2010 04:27 AM
Houston, we have a problem AZgl1800 Miscellaneous Forum 6 07-22-2009 07:33 PM
Napa Employee, I think we have one or two on this board! longhaireddwb General Motorcycle Discussion Forum 24 03-08-2008 10:43 AM
We don't have that item in stock but we can order it for you. It'll be here in two days halls51 General Motorcycle Discussion Forum 19 05-14-2007 08:40 AM
