Need something to fill a rusty pipe - Page 2 - Steve Saunders Goldwing Forums
 8Likes
post #11 of 48 (permalink) Old 05-28-2019, 10:35 AM Thread Starter
Originally Posted by DenverWinger View Post
How about welding some plate steel or angle iron to the OUTSIDE of it? Or just get another cross member (This is the removable transmission support, I assume?) from a junk yard...
No it is not removable, at least not meant to be. Jut getting everything loose from it so it could be cut out would be a major operation. I'm just not going there. I can weld some support on it. Would be easier to replace the entire frame, if one could be found.
post #12 of 48 (permalink) Old 05-29-2019, 01:20 AM
Year: 2006
Would rather not add that much weight.
Then use concrete and poultry net . A common way to repair rusty cars before we got regular safety inspections
post #13 of 48 (permalink) Old 05-29-2019, 05:00 AM
dwade's Avatar
Year: 1989
Model: Aspencade
The made me laugh. My wife and I are working on the family home (built in 1860) and the threshold to the front door was packed with concrete including about the first 5 inches of the side boards of the door frame.
Sent from my SM-G950U using Tapatalk
dwade is offline
post #14 of 48 (permalink) Old 05-29-2019, 05:17 AM Thread Starter
I thought about concrete but where would I use the poultry net?
post #15 of 48 (permalink) Old 05-29-2019, 06:43 AM
DenverWinger's Avatar
Home Depot sells rebar
1972 CL-350 (1980-1988) sold
1977 GL1000 (2002-2006) sold
1993 GL1500 Aspencade (2017-)
1983 Trav-Lite Camper (2010-)
DenverWinger is offline
post #16 of 48 (permalink) Old 05-29-2019, 08:27 PM
Model: '98 Valkyrie
this might work
http://www.hardblok.com/
ValkyrieRider is offline
post #17 of 48 (permalink) Old 05-29-2019, 10:21 PM Thread Starter
Originally Posted by ValkyrieRider View Post
this might work
Excellent, just what I was looking for.
post #18 of 48 (permalink) Old 05-30-2019, 12:53 AM
Year: 2006
You put the poultry net in first , - that way you get "reinforced concrete"
post #19 of 48 (permalink) Old 05-30-2019, 01:51 AM
I would get the "self leveling" type concrete, that way it would flow thru the tube from end to end....
you could help that along by jacking up one side of the pickup.
I used that stuff in a bathroom once because the floor was almost 2 inches out of level from one side to the next. the toilet bowl had never set solid in that house, and I finally did something about it. worked great.
post #20 of 48 (permalink) Old 05-30-2019, 06:19 AM Thread Starter
It would be close to impossible to get it through the tube. It has 4 approx 45 deg. bends.
