Kuryakyn Chrome L.E.D. Trunk And Saddlebag Molding - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 10-12-2006, 07:31 PM Thread Starter
Kikker's Avatar
Model: 2012 GL1800 Nav/XM
Does anyone have this Kuryakynsetup on your GL1800? Did you install it and how difficult was it to install? How is the wiring connected?
I really like the way this chrome and lighting setup looks but I hate slicing wires.
The value of our lives comes not in what we do or whom we know, but by who we are.
Goldwings I've had the privilege of owning
1977 GL1000
1982 GL1100 Aspencade
1984 GL1200 Aspencade
1987 GL1200 Aspencade
1988 GL1500
1994 GL1500-SE
2006 GL1800
2012 GL1800
Vietnam Combat Veteran 11B40
Kikker is offline
post #2 of 5 (permalink) Old 10-12-2006, 09:01 PM
RedWinger is offline
post #3 of 5 (permalink) Old 10-12-2006, 09:08 PM Thread Starter
Kikker's Avatar
RedWinger,
Thanks for the pictures. That's a beautiful Wing.
If you mounted the fog lights, did you have any problem adjusting them? What did you use to fill up the gap between the cowling and the fog lights. I've got about a half inch space and the hole doesn't line up perfectly with the bulb.
1977 GL1000
1988 GL1500
1994 GL1500-SE
2006 GL1800
2012 GL1800
Kikker is offline
post #4 of 5 (permalink) Old 10-12-2006, 09:17 PM
post #5 of 5 (permalink) Old 10-13-2006, 06:44 AM
To adjust the fog lights put the bike on the center stand,with the lights 5 feet away from a vertical surface such as a wallor garage door.Remove the lower cowell. Properly adjusted, the lights willproduce a horizontal line the same height as the lights. To raise the lineloosen the phillips screw head; to lower, tighten it. The gap you describe between the bulbs and the cut-out is normal.
Since the cowell is off, you may want to change the oil and filter.
Presitla99 is offline
Lighted Trunk Molding Wanted bwssr For Sale/Wanted Forum 0 06-26-2012 02:42 PM
Kury Trunk & Saddlebag Molding LED Light Bars TitaniumWing General Motorcycle Discussion Forum 1 04-09-2010 10:46 PM
Kuryakyn Chrome Tubular Radiator Grill tallyho For Sale/Wanted Forum 3 07-01-2009 06:40 AM
kuryakyn chrome fender tips bluesuub Goldwing Technical Forum 4 05-22-2008 03:28 PM
Kuryakyn chrome timing chain cover 07Silver Goldwing Technical Forum 13 01-21-2005 06:33 PM
