While on the subject of lifts: - Steve Saunders Goldwing Forums
post #1 of 13 (permalink) Old 03-28-2007, 10:22 AM Thread Starter
Hobie1's Avatar
If so, how is it holding up for you? Do you like the ease of use or is it a PITA? Any other issues?
Regards,
Hobie
Mark
Wineberry 1983 Interstate
Hobie1 is offline
post #2 of 13 (permalink) Old 03-28-2007, 11:09 AM
Already replied on mine in the other thread. I bought the good aluminum one from Sears on the last tool sale.
So far, so good. Like it because it is easier to move around. I can pick it up and hang it on the wall without a lot of effort.
Used it three times so far. No issues.
post #3 of 13 (permalink) Old 03-28-2007, 11:10 AM
Monkey with a Football
Rudy's Avatar
How many threads are you going to start on this subject????
Sorry Hobie.. didn't notice you had switched to aluminum on us.
Rudy
wasn't too much fun”
Rudy is offline
post #4 of 13 (permalink) Old 03-28-2007, 06:43 PM Thread Starter
Hobie1's Avatar
As many as needed Rudy.
Hobie
Mark
Hobie1 is offline
post #5 of 13 (permalink) Old 03-28-2007, 06:45 PM
Tattoo Taffy's Avatar
i have some binford milk crates and a few strong mates, works everytime.......
Tattoo Taffy is offline
post #6 of 13 (permalink) Old 03-28-2007, 06:53 PM
Rudy's Avatar
But what about the bike?
Rudy
Rudy is offline
post #7 of 13 (permalink) Old 03-28-2007, 06:55 PM
no problems, i just whistle and up she goes................
post #8 of 13 (permalink) Old 03-28-2007, 07:19 PM
OnaWingAndaPrayer's Avatar
Model: 94SE 209000 miles
I have an aluminum jack rated 1500lbs. Its branded "CrewLine" ,from what I can tell its the same one sears sells. Front wheels are wide spaced and rear are mch closer together. I think thats the one your refering to. I have had it a yr now and used several times . Even used it as a transmission jack for my sons 4X4 truck. ITs been fine . Though I did find I needed to slightly open the vent screw for it to work . I think it is closed (vent screw) to hang on the wall.
NASSIR 1
NASSIR 6
NASSIR 7
NASSIR 8
NASR 10 Good times!
OnaWingAndaPrayer is offline
post #9 of 13 (permalink) Old 03-28-2007, 07:46 PM Thread Starter
Hobie1's Avatar
Thanks folks.
I'm going to buy one tomorrow and hopefully also fix my red one. I think if I can get the red one to work, it would be a nice addition to when I drop one or the other wheel off to put under the wheel remaining to keep things balanced better.
Positive thoughts, positive results.
Hobie
Mark
Hobie1 is offline
post #10 of 13 (permalink) Old 03-29-2007, 01:28 PM
QuienSabe's Avatar
I have trouble with my "red" one because it is too high to slide under a couple of my cycles unless I hold them vertical to start, which is a bit tricky for a single person.
I think the more expensive model ( I am assuming that is the aluminum one you speak about ) lowers to 4" as oppossed to 5.25". That would make my life much easier. Can anyone confirm the minimum height of the aluminum lift?
Jim
1984 Honda GL1200A
2002 Honda Magna VF750
2006 Honda VLX600 ( wife\'s )
May the source be with you.
QuienSabe is offline
Subject tbarber1027 Test Forum 0 12-18-2011 04:58 PM
No Subject TJ ARGAZZI New Members Introduction Forum 14 10-21-2010 02:32 AM
A sensitive subject BustedKnuckle General Motorcycle Discussion Forum 23 07-15-2010 03:34 PM
Unmentionable subject woodbutcher General Motorcycle Discussion Forum 31 02-26-2008 09:53 PM
