My First Complaint about the 1800...Bars Shaking at 40- Mph - Steve Saunders Goldwing Forums
post #1 of 11 (permalink) Old 02-11-2008, 01:47 PM Thread Starter
As ya'll are aware I totally like my wing. The only complaint i have is that when you let go of the bars(grabing something or adjusting something) the bars shake tremendously, under 40mph. After 40 you can let go all day but for some reason they shake under 40. Anybody know why?
Goldwing\'s are like riding a sportbike with tunes, storage and in total confort. Can\'t beat that with a stick.
gixxerbill is offline
post #2 of 11 (permalink) Old 02-11-2008, 01:55 PM
Goldwing Addict :-)
Jluvs2dive's Avatar
Model: GL1500SE, GL1200A
Send a message via AIM to Jluvs2dive Send a message via MSN to Jluvs2dive Send a message via Yahoo to Jluvs2dive
Actually there has been much discussion about this, up to and including mention of a lawsuit. There are opinions that either the wheel bearings or steering head bearings adjustment or replacement can fix the problem, but nothing totally definitive. Just do a search on front wheel wobble and you should bring up some discussions on it.
Bought with just under 9000 miles on 08/19/2008
also
84 Aspy
84 Interstate
past
86 GL1200 Aspy
84 Standard
87 Interstate
80 Yam Midnight Special 1100
79 Suz SP400 Enduro
72 Honda SL350
81 Honda XR500
Jluvs2dive is offline
post #3 of 11 (permalink) Old 02-11-2008, 02:14 PM
Old School Guru
GLester's Avatar
Year: 2007
Make: Goldwing
The front wheel wobble has been around since the first Goldwings. There are all kinds of different theories as to why most GWs shake from 30-45 mph, some can be cured by head bearing adjustment, some by different tires, some by fork braces, but one thing for certain, as long as you keep your hand on at least one handlebar, it doesn't shake, so I don't take my hands off totally until I'm doing over 50 mph.
Gene
Gene Lester
Arkansas Chapter
Darksider #265
GLester is offline
post #4 of 11 (permalink) Old 02-11-2008, 02:15 PM Thread Starter
Thanks. I will do some lookin' around. I wonder if a ohlin damper would help? That would seem easier than messing with the wheel bearings and steering head.
post #5 of 11 (permalink) Old 02-11-2008, 02:18 PM
Goldwing Addict :-)
Jluvs2dive's Avatar
I will say that on my 1200, I don't have a wobble for the first 5K-6K miles on new tires, then it starts showing up.
also
84 Aspy
84 Interstate
past
86 GL1200 Aspy
84 Standard
87 Interstate
79 Suz SP400 Enduro
72 Honda SL350
81 Honda XR500
post #6 of 11 (permalink) Old 02-11-2008, 04:18 PM
Geordiemuppet's Avatar
Year: 1975, 2015
Model: GL1000, GL1800
Yep, because there is something wrong with it.
If its new, take back to the dealer and play merry hell and demand satisfaction. If its not new, check out the threads on here as suggested.
Paul
2015 GL1800 40th Anniversary Ladybug.
1975 GL1000K0
1992 ST1100M
Confusion will be my Epitaph....
Geordiemuppet is offline
post #7 of 11 (permalink) Old 02-11-2008, 04:30 PM
SB in SC's Avatar
Location: Edgefield -Capitol of the South-, South Carolina, USA
My 1100 had that shake, but my 1500 shows no signs of it at all.
Sean, the Resident Redneck
1997 GL1500 Aspencade Limited Edition
1983 GL1100 Aspencade
Freemasonry--2B1ASK1
"Fear the government that fears YOUR guns."
SB in SC is offline
post #8 of 11 (permalink) Old 02-11-2008, 06:11 PM
Must have been all those wheelies you were doing Be cool.....just messing with you a bit! I have my own idea about front end wobble with bikes. The wing is not the only one that does this.....lots of various bikes develop this. My new Wing is steady and true.....the factory dunlops do like to do the cakewalk on grooved pavement.....but back to the wobble. Tires can and do cause this......that is one for sure cause.
Bearings? okay.......put in tapered or better bearings and tighten them down......tension does control the wobble but does not get to the root of the problem.
I have always felt......and experience on several bikes.......some kind of out of alignment situation where the rear is not in alignment with the front....one works against the other.......and is quite noticeable at low speeds.......as speeds increase and the gyro effect gets going good.......it just goes away........
Know how to stretch a string around the front tire and pull it taunt with the rear? If not you can do a search for this and it will show up for you........this situation used to be very common on the bikes I grew up riding(Harleys.......shhhhhhhh!!!) sometimes it would be bad...sometimes not so bad.....depends on how well you got the rear tire lined up after a tire change or adjustment of chain or belt. But would cause the front to wobble at low speeds...........and again at extreme high speed........that is called a tank slapper........not a fun deal!!
Check your front to rear alignment.......if a new tire does not work......Just my penny's worth ........have not had a wing long......but had lots of bikes........I suppose on the wing if found to be out of line......shims.......or spacers.....would work. Kit
Kit
Kit Carson is offline
post #9 of 11 (permalink) Old 02-12-2008, 08:37 AM Thread Starter
Thanks Kit I will try those suggestions. And I have been trying to keep the wheel down.
post #10 of 11 (permalink) Old 02-12-2008, 08:51 AM
Old School Guru
GLester's Avatar
Year: 2007
Make: Goldwing
There was also some discussion about it in this month's Wing World magazine, pretty much what the GWRRA guru had to say about it was it thoughtto do with the rake and length and weight of the bike had something to do with it. Like I said before, there are many different theories, and a lot of different cures or fixes.
Gene
Gene Lester
Arkansas Chapter
Darksider #265
GLester is offline
crash bars /highway bars for a gl1100 timbrains Goldwing Technical Forum 5 07-09-2011 12:04 AM
Handle Bars Weights On GL 1800 2005 Rushmore Goldwing Technical Forum 2 05-27-2011 03:10 PM
Shimmy on the bars at low speed 2003 wing 1800 blue knight Goldwing Technical Forum 40 12-20-2009 06:47 PM
Cops looking for 90 mph violator in 40 mph zone AZgl1800 Fun Forum 1 11-29-2009 01:57 AM
1800 handle bars baggy Goldwing Technical Forum 3 05-19-2008 12:39 PM
