Bringing an 1100 home...truck OK? - Steve Saunders Goldwing Forums
post #1 of 14 (permalink) Old 06-26-2008, 12:54 PM Thread Starter
vwtom's Avatar
Hello - I have found an 1100 and now I need to go get it.
I'm thinking of using a truck with the 6' bed. I know I'll have to find a ditch to load it up, but can I get it all strapped down OK. I assume I'll have to leave the tailgate down.
Thanks - I appreciate all the help.
Looking for a 1200.
vwtom is offline
post #2 of 14 (permalink) Old 06-26-2008, 01:07 PM
Old School Guru
GLester's Avatar
Year: 2007
Make: Goldwing
As long as you can get it tied down good and loaded, it should not be a real problem. Most 1100s weigh under 800 lbs, so most pickups should be able to handle it. I would recommend however, that you put the bike in diagonally in the bed, most tailgates would get a workout with 400-500 lbs riding on them for long distances. Just put the front wheel up into one corner, and the rear wheel the oposite rear corner. You might not be able to shut the tail gate, but you will get both wheels in the bed of the truck. It will be a little harder to tie down this way, but i feel it is safer on a short bed truck.
Gene
Gene Lester
Arkansas Chapter
Darksider #265
GLester is offline
post #3 of 14 (permalink) Old 06-26-2008, 01:14 PM
Endwell_Tim's Avatar
That's how I do it, I have an old S10. Well, I had to do it once, anyway. Just mind your plastics, don't rely on either stand to hold it up, and yes the tailgate will stay down.
[COLOR=GREEN]Endwell_Tim
81 GL1100I ---->>>> GONE!!!
90 GL1500 SE
"Opportunity is most often missed because it shows up in overalls, lookin\' like work..."
Endwell_Tim is offline
post #4 of 14 (permalink) Old 06-26-2008, 01:56 PM Thread Starter
vwtom's Avatar
Gene
It's a full size truck (1/2 ton), so I wasn't too worried about the weight. Just didn't know if it would fit diagonal with the bags on.
Looking for a 1200.
vwtom is offline
post #5 of 14 (permalink) Old 06-26-2008, 02:31 PM
Matt G's Avatar
Send a message via AIM to Matt G Send a message via Yahoo to Matt G
I have fit a GL1000 with fairing and bags into the back of a El Camino, so a full size truck will be no problem.
Current Goldwing:
1988 GL1500 Wings of Freedom
We tried voting with the Ballot box, When do we start voting from the Ammo box, and am I allowed only one vote ?
Matt G is offline
post #6 of 14 (permalink) Old 06-26-2008, 05:07 PM
Model: GL1500
Or better yet, let someone drive you there.........and ride the thing back....remember, you have bought a WING not a HARLEY!.....
JK........Jenn put her or her husbands 1100I in a S-10 p/u......I would get some of the ratchet straps to tie it down with, not the cheap ones that have the little push thingy (rather technical) on it....I just dont trust those.
You should be ok with a full size truck though........Oh, and congrats on getting your wing. Was that the 2500 one? or did you find another?
Served 823rd RED HORSE Unit \'83-\'88 USAF
\'Semper Ducimus\'
Red Knights Alabama Chapter 2
"Loyal to our Duty"
PGR Alabama Div.
1983 CX500 Custom
1981 GL1100 Standard
1982 GL1100 Aspencade
1985 GL1200 LTD
nightwizard40 is offline
post #7 of 14 (permalink) Old 06-26-2008, 05:38 PM
put an 8 foot sheet of plywood in the truck......the weight of the bike holds it in and down....and gives you the length you need to put the bike in straight and then take off the seat and strap it down good.......in the front....across the seat.....and somewhere on the back. Kit
Kit
Kit Carson is offline
post #8 of 14 (permalink) Old 06-26-2008, 05:41 PM
DigbyODell's Avatar
Congrats vwtom
If it is up thisway and you need some help, give me a shout (Dubuque)
^^2003 BLACK 1800
^^ 2003 Kawi Meanstreak
US became socialist on 02/17/09 God rest her soul
My SUV just burned up the gas your prius saved... Thank you
DigbyODell is offline
post #9 of 14 (permalink) Old 06-26-2008, 06:38 PM
kysportsman's Avatar
Hi I went a couple of week to pickup my 1500 but decided the problems with trying to haul it in my pickup was more than I wanted to deal with.
So I renting a 5x9 open uhaul trailer with a large drop down end gate. Loading and hauling was so easy with this trailer.
They are a local rental you rent it in you town or close and return it to the same place. I think the rental was $24.95 plus $5.00 insurance which covered the trailer and load.
I think it was well worth the cost. James
kysportsman is offline
post #10 of 14 (permalink) Old 06-26-2008, 08:39 PM
redbaron's Avatar
Model: GL-1500
Kit took the words right out of my mouth...3/4 in ply wood and good ratchet straps Double straps on each point you tie it down at and take the seat off and put at least one across where the seat was..I'm just passing on what some others posted about hauling one.....Good luck with the "new" Wing....
Claude
Honorary member Wild Rhinos
redbaron is offline
In search for headlight and headlight bracket? GL 1100 1981 bringing it back to life! ryster For Sale/Wanted Forum 7 04-04-2010 08:30 PM
Bringing home a barn find...bring up sequence needed please RikPardun Goldwing Technical Forum 11 07-04-2009 09:43 AM
Bringing home a barn find...bring up sequence needed please RikPardun Goldwing Technical Forum 6 07-01-2009 11:24 AM
Bringing work home with me........... :) Jennifer General Motorcycle Discussion Forum 21 06-06-2008 05:59 PM
Im bringing her home today muaymendez1 General Motorcycle Discussion Forum 3 07-23-2007 09:44 AM
