Final drive problem GL1500 reassembly - Steve Saunders Goldwing Forums
post #1 of 7 (permalink) Old 08-01-2008, 04:17 PM Thread Starter
wingannaprayer's Avatar
While I was going to replace my tires, I decided to lube the final drive splines on the driven shaft as well as the splines going into the universal joint. The final drive assembly came out without a hitch. Did my cleaning and lube, reassembled the shaft in the hub and tried to reinsert up drive tunnel but shaft will not go into the ujoint yoke. This has really got me stumped as there is no blockage and everything looks clean. Has anyone a reccomendation as how to reinsert the drive shaft? It's an '89 GL1500. Would appreciate any help you can give.
wingannaprayer is offline
post #2 of 7 (permalink) Old 08-01-2008, 04:33 PM
Wolfman's Avatar
Model: GL1500SE
Yes, I have had this problem.
Take your coupling out of the wheel and put it into the hub and use it to turn the driveshaft back and forth.
As you are pushing the driveshaft into the u-joint turn the coupling back and forth and it will make the u-joint wiggle enough so that it will line up and slide in.
If you want some good reading, I describe my 3 day ordeal at the bottom of my page: http://www.hrot.org/martino/goldwing...driveshaft.htm
Yes, the first time I did the job, I wasted 3 days. But never had a problem since.
Jim
Beware, I'm a known thread hijacker.
'96 GL1500 SE
Honda Riders of Tidewater -- Former Chapter President
My personal webpage:
Desert Storm Veteran USS Pensacola (LSD-38)
Wolfman is offline
post #3 of 7 (permalink) Old 08-01-2008, 06:04 PM
lostinflorida's Avatar
I had trouble with my 1200 once. The u-joint has the tendency to dip down just a hair and make it hard to line up and get the splines started. It takes a little effort and some gentle twisting while you are trying to get it to mate.
"The Duke of" Earl.
PGR member
IBA member #32000
lostinflorida is offline
post #4 of 7 (permalink) Old 08-01-2008, 06:39 PM
wda-83wing's Avatar
Model: 83 GL 1100 I
wolfmam--nice write up.
wda-83wing is offline
post #5 of 7 (permalink) Old 08-01-2008, 07:59 PM Thread Starter
Wolfman, thankyou so much for the greart advice. Worked like a charm!!!!! One little addition to your excellent write-up. Put the bike in park and the u-joint won't move at all. Makes lining up a lot easier. Again, thank you.
post #6 of 7 (permalink) Old 08-01-2008, 10:21 PM
Senior Guru
Oregonwinger's Avatar
With cold oil, I hit the starter button (in neutral), while keeping slight forward pressure on final. Pops right in every time. There's enough drag on gears with cold oil, it rotates the output gently, without causing any sudden grabbing/lurching problems.
BOB
Oregonwinger is offline
post #7 of 7 (permalink) Old 08-02-2008, 12:04 AM
jimsjinx's Avatar
Model: 1999 1500SE Motortrike
Nice site Wolfman! Thanks, I learned alot.Like I'll hire you to rebuild my carbideezers! LOL Again, nice job. jimsjinx
"We are put here, to take care of each other"
jimsjinx is offline
GL1500 final drive and drive shaft removal tutorial uploaded wingnut Goldwing Technical Forum 15 09-22-2011 04:52 AM
GL 1500 final drive reassembly wingannaprayer Goldwing Technical Forum 7 08-03-2008 01:53 PM
Want Final Drive and Drive Flange/Rear wheel for 88/89 GL1500 4evermetric For Sale/Wanted Forum 0 09-20-2007 04:58 PM
Problem reinstalling final drive and the u joint is actually past the boot and into the tube. fasman Goldwing Technical Forum 8 05-17-2007 09:34 AM
Wanted: GL1500 Final Drive, 88 or 89 GL1500 Drive Flange, GL1500 Driveshaft tuntrep For Sale/Wanted Forum 0 07-09-2006 08:06 AM
