Homemade clutch repair tools - Steve Saunders Goldwing Forums
post #1 of 4 (permalink) Old 04-01-2009, 11:30 PM Thread Starter
Elgeek's Avatar
Hi Folks,
If anyone is interested i overhauled my 1200 this spring, and when it came to replacing clutch plates, I found myself not having the correct specialty tools.
First item I needed was the special four prong wrench which can be made with a standard plumbing pipe, 1-1/2'' ,
Then I needed to hold the clutch from turning when removing, my friend suggested a tie downstrap, which we put around the clutch cage and used the long bolt on the right side as an anchor. This allowed removal of clutch.
Next was to remove spring clip, this required another special tool which I made out of PVC vacume pipe, and I cut out a notch just lage enough to put spring clip pliers in to release clip. I used a flat wood working vice to compress the spring plate with just enough pressure that I could move the spring clip freely.
This worked very well, and with little effort all the rest was completed using all the other tips I received like making sure the stamped edges followed the same direction.
If anyone is interested I have taken pictures of the tools I made and will email to anyone who would like them. I will put a couple of small one in post as a start.
Elgeek is offline
post #2 of 4 (permalink) Old 04-02-2009, 04:37 AM
RayandTracy's Avatar
very impressive, I'll pm you later for some photos if you don't mind or you could just post them on photobucket save you emailing a bunch of folks.
Ride Safe, Ray
RayandTracy is offline
post #3 of 4 (permalink) Old 08-22-2011, 12:44 PM
could you please email me pics of the tools you made? I will be doing my clutch next week and would like to be prepared.
[email protected]
md1201 is offline
post #4 of 4 (permalink) Old 08-22-2011, 11:01 PM
Village Whack Job...
Broke Winger's Avatar
Model: '81 GL1100 Interstate
When I did the clutch on my 1100 (repeatedly) I just put the bike in gear to hold the clutch basket still.
P.G.R. Member ID: 88374
Broke Winger is offline
Homemade Sealmate - fork seal repair tool William_86 Goldwing Technical Forum 34 04-15-2014 07:57 PM
Homemade Bearing removal Tools for gl1200 RayandTracy Reference and FAQ Forum 24 06-21-2009 03:43 AM
83 GL1100 clutch tools maxt Goldwing Technical Forum 2 07-15-2007 08:03 PM
76 1000 clutch replacement tools? scmopar Goldwing Technical Forum 2 05-27-2006 09:41 AM
clutch removal tools lewisjon Goldwing Technical Forum 3 05-14-2006 11:42 PM
