Bike Painting - Steve Saunders Goldwing Forums
post #1 of 15 (permalink) Old 04-22-2009, 09:34 AM Thread Starter
revalator's Avatar
Well as some of you know I got a 82 Aspencade this year, nice bike, but the pinstriping is very worn on some area. The trunk and bags. I want to get the bike painted, but I cant afford 700 to 800 dollars to have it done. Has anyone tried to remove the pinstriping and redo it? can that be dome.
Any ideas will be welcome. Or if you want to paint it for me, Maybe we could work out a payment plan. I dont use credit cars, thats why i cant just get it done.
Plus my surgery I had this year will be setting me back about 3 or 4 grand
revalator is offline
post #2 of 15 (permalink) Old 04-22-2009, 11:51 AM
Hey Revalator,
My only idea would be to use a hot, wet cloth and try soaking the stripe for awhile. I dont know if it will work but if it does, let us know, as lots of us are having this problem.
post #3 of 15 (permalink) Old 04-23-2009, 07:46 AM Thread Starter
revalator's Avatar
bump
post #4 of 15 (permalink) Old 04-23-2009, 10:42 AM
Try Easy Off oven cleaner. Has worked for others.
post #5 of 15 (permalink) Old 04-23-2009, 02:31 PM
oldtoys1961's Avatar
Usually their clear coated over. SO to get off the original stripe the rest of the clear has to be removed. Problem is its always the clear on the stripes that seems to wear off. And its usually not on all the stripe. It also chips and peels around the edges of the pin stripping. If the clear around the edges aren't too shot you can usually go to a auto store and pick up a good brand of stickon and just go over the old.Maybe go 1mm or a little larger than the stock width to cover the peeled and chipped edge of the original. That stuff sticks like no tommorrow and once waxed over holds even better. Other than that, a repaint and pinstripping then clear. JR
"Please Tell Your Boobs To Quit Staring At My Eyes"
1983 GL1100I
oldtoys1961 is offline
post #6 of 15 (permalink) Old 04-23-2009, 11:07 PM
3rdwing's Avatar
Model: 2008 Comfort/Navi
Easy off worked on the pinstriping on my 89. Used it to remove the names when I traded up to my 1800.
3rdwing is offline
post #7 of 15 (permalink) Old 04-24-2009, 08:57 AM
Guest
Posts: n/a
didnt mess up the paint?
post #8 of 15 (permalink) Old 04-24-2009, 09:48 AM
redbaron's Avatar
Model: GL-1500
I started to tell my tale of adventures in painting my Wing, but I got rather long winded ...I do that at times...So here is my advise, remember advise is like elbows, everyone has at least one or two.... A little back ground here, For the last year I have been , between some bad health issues between my wife and my self, plus a crazy work schedule, I have been trying to rebuilding my 82 Interstate, plus doing a first class paint job.....
My advise is this....If its just the pin stripping try what oldtoys1961 said, or just save your money up and do a complete paint job...I don't know any where here you can get a complete paint job on a Wing for $700.00.....There are about 15 pieces on a Wing that would have to be removed, badges, latches, and all mounting hardware removed, bagged and tagged for re-installation....When I say 15 pieces I'm counting every piece, lids, bags, fenders, etc....It is a bunch of pieces...
The paint and all of the odds and ends, primer, flex additives, base coat, clear coat, and this does not take in sand paper, etc for my Wing is almost $400.00, now factor in labor and you will find out that paint shop labor runs any where from $50 to $75 per hour......And trust me it is going to take more than one hour to get all these pieces ready for primer, then re-sanding and then your paint job....
I have been to several paint shops in my area and the least amount I have found was close to a major heart attack, several thousand dollars, or more, for a turn key paint job..Your discount paint shops won't even do a bike paint job....So if you are determine to re paint your Wing....I suggest that you gather up a bunch of your friends, buy some liquid beverages, fire up the barbie, put on some rock and roll on the radio, and have a paint party....
Paint work can be a nightmare ask me, but by hopefully the end of June mine will be finished, and rideable again...
Claude....
Honorary member Wild Rhinos
redbaron is offline
post #9 of 15 (permalink) Old 04-24-2009, 11:06 AM
3rdwing's Avatar
No, it didn't mess up the paint. Actually I asked the guy that pinstriped it and he told me to use Easy off. He did say that it might leave the area where the easy off was applied a bit hazy and I might have to buff it to restore the shine, but I had no such trouble. The pinstriping was painted on, I dont believe it was clear coated.
3rdwing is offline
post #10 of 15 (permalink) Old 04-24-2009, 11:17 AM
Jackhammer01's Avatar
revelator, the pinstriping on the 82 is applied, not painted. And the clearcoat is on top. That leaves a couple of options.
1) Since you plan to repaint, use 80 grit on a palmsander, break the clearcoat seal, and then warm it with a hair dryer, in sections, and it will actually peel off. Finish sanding the entire piece, to get it ready for primer.
2) Use 80 grit to completely sand the entire piece, including the pinstriping.
I use dupli-color paint from a can, available from Advance Auto Parts. Only problem, the color choices are limited. But take your time, prep it right, and you can still do a first class paint job, for approximately $100.
I have never used, or heard of using, Easy-Off. Might be worth it, just to test it.
Jim Horton
Myrtle Beach SC 29588
843-274-5045
Patriot Guard Rider
Jackhammer01 is offline
preping bike for painting dwvassar Goldwing Technical Forum 6 03-03-2011 05:09 PM
I just finished painting my bike - check it out. norton General Motorcycle Discussion Forum 18 05-10-2009 02:48 PM
Painting wander1249 Goldwing Technical Forum 2 04-19-2009 06:30 PM
PAINTING carpman Goldwing Technical Forum 11 03-13-2009 05:45 PM
Painting my bike Knucklebucket General Motorcycle Discussion Forum 19 12-18-2008 05:12 PM
