which satelite radio for a 2005 gla 1800 - Steve Saunders Goldwing Forums
post #1 of 2 (permalink) Old 04-09-2010, 10:13 PM Thread Starter
my friends i need advice on which type of xm radio to put on the wing, looking for one that shows less wire and can use on board power system, the 12 on the bike, please advise, Hucklebuck
A BAD DAY RIDING BEATS A DAY IN THE RECLINER
old141fe is offline
post #2 of 2 (permalink) Old 04-09-2010, 10:42 PM
TitaniumWing's Avatar
Model: 2006 Goldwing
The Zumo 550 GPS is the high dollar way to go, great GPS with built in XM and cell phone interface, water resistant and has motorcycle mounting options, it was designed for motorcycles, but it isn't cheap 650 to 850 depending on where you buy it.
I went with Sirius, my rig is cleanly mounted on a RAM mount and I made the adapter to mount it to the round RAM mount. The chrome bar sticking up is a locking mount - (work in progress). It will have an aluminum block milled and attached to the top of it to secure the unit in place and it will be cut down to extend about 3/4" above the unit.
The buttons (presets) are small. I have an old helicopter headset plug with about 6" of cable left on it hanging from the mount, I use it as a stylus and it hangs neatly between the switch housing and RAM mount - otherwise I couldn't tune it with gloves on.
Downside, my rig is not water resistantso I cover it with a leather bag in the rain. Upside is it cost 100 bucks and I can pop it off and mount it on my home mount in my garage, or on my other car mount in my car.
The 12 volt adapter is hooked up inside the left fairing under the left fairing cargo compartment. Initially I had an irritating whine in the audio. Had to install a ground isolator from Radio Shack, then it worked perfectly.
Ground Loop Isolator Model: 270-054| Catalog #: 270-054 $16.99
See topic: https://www.goldwingfacts.com/forums/forum1/80244.html
I bought the short wired antenna from these guys, they also have some motorcycle mounts: http://www.tss-radio.com/
Patriot Guard Rider
Titanium Wing: 2006 GL1800 Airbag
"You might ride fast, but never ride in a hurry."
TitaniumWing is offline
Satelite Radio PORKCHOP General Motorcycle Discussion Forum 14 08-28-2011 01:45 AM
2005 gla 1800 dash part info needed old141fe Goldwing Technical Forum 6 11-22-2010 06:16 PM
wanted carbon fiber parts 2005 1800 gla old141fe For Sale/Wanted Forum 0 11-18-2010 06:46 PM
2005 gla 1800 front fork servicing and bearing replacement old141fe Goldwing Technical Forum 1 10-17-2010 07:05 AM
front fork removal on a 2005 gla 1800 wing old141fe Goldwing Technical Forum 6 02-27-2010 08:05 AM
