Emco fuel filter for GL1500 is discontinued - Steve Saunders Goldwing Forums
post #1 of 4 (permalink) Old 02-22-2011, 12:31 PM Thread Starter
Honda Guru
rayworx's Avatar
Year: 1988
Make: Honda GoldWing
Model: 88 GL1500
I found out from Honda Direct Line that Emco has discontinued production of the fuel filters for GL1500's. Apparently the new manufacturer's
quality was not up to Emco standards so they chose to discontinue the filter altogether.
That means that the only option will be the stock Honda filters…. at a much higher cost. If you find someone that's got the old filters in stock you might want to buy a few extra for future use.
This also might include the GL1000/1100/1200 fuel filters also but I don't know for sure.
Ray
88 GL1500
rayworx is offline
post #2 of 4 (permalink) Old 02-22-2011, 01:03 PM
No loss, just get a NAPA 3011
Much cheaper anyway.
It will work and fit WITH some mods. its a bit bigger around. i used a nut to level things out a bit. also a longer bolt (replaced screw) it has both 1/4 and 5/16 ends. the shell is on the thin side .it will slide a bit in the holder . but not with out pushing on it and the mounting bracket. it does not rattle around in the bracket. shown in this pic is the spacer nut and longer screw (bolt).
All of that info came from:
wda-83wing Senior Guru
See this link:
https://www.goldwingfacts.com/forums/forum1/102742.html
post #3 of 4 (permalink) Old 02-22-2011, 02:31 PM Thread Starter
Honda Guru
rayworx's Avatar
Year: 1988
Model: 88 GL1500
That might be ok for an 1000/1100/1200(like the one in the picture) but the 1500 is a 3/8" inlet and the amount of space available is limited. Plus I like the looks of a stock filter.
Just trying to inform ya all of some new info.
Ray
88 GL1500
rayworx is offline
post #4 of 4 (permalink) Old 02-22-2011, 03:46 PM
SabreJoe's Avatar
Thanks for the update Ray. I got me 4 OEM Honda filters stashed, got them half price. I reckon they will last me a while.
SabreJoe is offline
1500 Cruise filter, sub filter, air filter, fuel filter, and plugs The Fonz Goldwing Technical Forum 4 04-15-2012 10:09 AM
GL1500 Fuel Filter busdriver Goldwing Technical Forum 13 04-14-2012 02:46 PM
Emco Fuel Filter rideandslidejim Goldwing Technical Forum 12 04-25-2011 03:45 PM
Draining GL1500 fuel tank, and does it have a fuel filter? trikemiike Goldwing Technical Forum 1 08-29-2010 02:38 PM
GL1500 Fuel Filter Wyaatt Goldwing Technical Forum 6 04-03-2010 03:54 PM
