I have a "Double Dark" side... updates: 10.25.11 - Page 2 - Steve Saunders Goldwing Forums
post #11 of 161 (permalink) Old 08-31-2011, 08:48 AM
Hodgy's Avatar
Model: 97' SE, Two Tone Red --> 124,024 km as of November 2015
My E3 still has a lot of km's left in it so I won't be changing it until it is gone.
What pressure are you going to run it at ? Or for those who have had it for a while what are you running at ?
Avatar Photo was taken in the Crowsnest Pass between Alberta and British Columbia on Highway 3.
Hodgy is offline
post #12 of 161 (permalink) Old 08-31-2011, 10:04 AM
4evermetric's Avatar
us385south wrote:
4evermetric in Onalaska, Wa (and 'prolly Dub too.) can attest to how hard it is to pull a wide 195+ darkside tire off a Valk.
(Raising right hand) "I hereby attest that it isapain the the rearto get a Goodyear TT off a Valkyrie."
That okay?
Gun totin', motorcycle ridin', whisky drinkin', meat eatin' American. That's who I am...
2000 Valkyrie
1987 GL1200
1996 Motoguzzi Cali
Joined the Darkside-03.28.2010
Iron Butt Association, #38226
Robert Morris Lodge #97F&AM
4evermetric is offline
post #13 of 161 (permalink) Old 08-31-2011, 10:21 AM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
Hodgy wrote:
... What pressure are you going to run it at ? Or for those who have had it for a while what are you running at ?
> I use 41psi on the wintersport, which I arrived at by testing to attain a full contact patch across the width of the tire; my first one at 20k miles was evenly worn across the center section.
> Someone recently posted about experiencing an annoying wobble with this tire... I believe the cause was due to their use of a lower pressure, 30 psi as I recall. If that's the cause, then i'd say that the higher pressure makes for a more Rounded profile (or One high spot in the center of the tire rather than 2 on the edges)
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
post #14 of 161 (permalink) Old 08-31-2011, 09:19 PM
OnaWingAndaPrayer's Avatar
Model: 94SE 209000 miles
I am itching to pull the trigger on a Wintersport . Waiting to read a bit more about theROF on the 1500. Anyone running this tire in southern high temp climates , summertime ? 2 up loads ?
I guess actually several of you in this thread qualify as southern . I just wonder about hight asphalt temps added to 2 up loading in summer weather .
NASSIR 1
NASSIR 6
NASSIR 7
NASSIR 8
NASR 10 Good times!
OnaWingAndaPrayer is offline
post #15 of 161 (permalink) Old 09-01-2011, 08:37 AM
Well I have two Friends with Valks that are already on the DS, So I have been watching all of the GW GL1500 threads on this with interest. But I was in no hurry to cross-over seeing as I had still had a lot of life left in my Pilot GT's That was until my rear tire ate a piece of scrap metal on my Sunday ride. So I pulled the trigger & I now have a Wintersport ROF on the way from Tire Rack, so I will soon get a chance to see what it is like on the "Dark Side"
God Bless, archerrj (Rick Mattson)
Darkside 175/60R16 Dunlop SP Winter Sport 3D RunOnFlat
archerrj is offline
post #16 of 161 (permalink) Old 09-01-2011, 09:08 AM
> Yes, the wintersport works fine in all temperatures. Can't tell any difference in traction from 25F - 110F, even riding 2-up with trailer.
I void warranties
KJ6QFZ
Dark Side #590
post #17 of 161 (permalink) Old 09-03-2011, 12:32 PM Thread Starter
us385south's Avatar
Year: 1996
Model: 1500
Alrighty... my Blue Ox is floating in the air and the rear wheel is off. This is a side by side comparison with the Wintersport 175 along side the Michelin Pilot GT.
The Pilot is mounted and the winter Sport is loose...
us385south is offline
post #18 of 161 (permalink) Old 09-03-2011, 03:51 PM Thread Starter
us385south's Avatar
Year: 1996
Model: 1500
Even MORE updates. I have the tire mounted.[line]
[img]http://www.culleynet.com/zen/Goldwing%20Tech/winter-service-2011-12/DSC08585_X640W.jpg.php?p=*full-image[/img]
Just less than 3/4" smaller in total diameter.
I actually believe this tire is about 1/4" less wide that the Michelin GT, alleviating clearance issues altogether.
[line]
[img]http://www.culleynet.com/zen/Goldwing%20Tech/winter-service-2011-12/DSC08587_X640W.jpg.php?p=*full-image[/img]
Just a tad bit thinner... and should lower the bike about 3/4".
I am deep into winter service on the wing. Installing a CB, and a gob load of other things I have been postponing... so riding it will have to wait for awhile. Wanted to get the wheel back on so I can move the bike around...
More to come.
post #19 of 161 (permalink) Old 09-03-2011, 05:54 PM Thread Starter
us385south's Avatar
Year: 1996
Model: 1500
The wheel is back on the bike... I needed to get it re-installed beacuse I need to have the option of moving the bike around. I would say that the wheel went back on easier than the Pilot GT. (Of course, that could just be that I am getting better at this.)
I must say that if this tire rides anything like it looks on the bike this is going to be a killer tire.
[img]http://www.culleynet.com/zen/Goldwing%20Tech/winter-service-2011-12/DSC08591_X640W.jpg.php?p=*full-image[/img]
[img]http://www.culleynet.com/zen/Goldwing%20Tech/winter-service-2011-12/DSC08592_X640W.jpg.php?p=*full-image[/img]
Alright you 1800 guys... where do i get one of those Darth Vader darksider decals? Cuz... I'm there, baby!
<!--insert sound byte of the Imperial March here-->
[align=center]"Once down the path to the dark side you begin...
Forever will it dominate your destiny!"
Yoda... a long, long time ago.
[/align]
Cheers... gotta jet for now...
385
post #20 of 161 (permalink) Old 09-03-2011, 07:39 PM
pcfix_3's Avatar
Year: 2004
congrats, now go get your cookies.
There really is nothing like riding on a wing.
Total Bike Miles: 106,000+ wing miles and counting.
Current rides: 04 GL1800 (my baby), 14 Yamaha Star Bolt
Previous Rides:
1980 Suzuki GS1000, USS Louisiana Gold (SSBN 743)
pcfix_3 is offline
Dark side in the UK akwright General Motorcycle Discussion Forum 12 09-02-2012 01:16 PM
Dark side DigbyODell General Motorcycle Discussion Forum 3 04-24-2010 06:09 PM
The dark side................... Hatchetman General Motorcycle Discussion Forum 7 04-09-2010 10:25 AM
Dark side DigbyODell Fun Forum 5 10-03-2009 02:58 PM
I have gone to the dark side DaveO430 General Motorcycle Discussion Forum 10 10-10-2008 10:37 AM
