GL1000 transmission shifting - Steve Saunders Goldwing Forums
post #1 of 8 (permalink) Old 02-10-2012, 03:40 PM Thread Starter
zimco's Avatar
Send a message via AIM to zimco
Can anyone tell me if a GL1000 should shift when it is not running?
I have 2 so far that will not shift out of neutral when the engine isn't running.
I can't run them long enough right now for various reasons (no clutch or throttle cable, etc) to try to shift them while running.
Any other bikes that I have had will shift, sometimes I have had to rotate the rear wheel slightly to get them to shift but these GL1000's just don't go into gear .
Any help will be appreciated
1967-69 Vietnam Vet
Life Member DAV
Patriot Guard Rider
1996 GL1500 SE Trike
1980 GL1100 Naked and Low
(1) 1975 GL1000 (being lowered)
(5) 1975 - 79 GL1000 Parts bikes
"Never try to teach a pig to sing
It wastes your time and it annoys the pig."
"You can also follow me on my blog Zimco\'s Garage"
zimco is offline
post #2 of 8 (permalink) Old 02-10-2012, 03:44 PM
Mine do, but if you've no clutch then there is nothing to couple the drive output to the wheel to rock it out of tension. Maybe turn the stator bolt to rock the tension of the gears so they'll shift.
CaptainMidnight85 is offline
post #3 of 8 (permalink) Old 02-10-2012, 04:30 PM Thread Starter
zimco's Avatar
Captain,
Correct me if I'm wrong.
Without a clutch it should be all hooked together, with the clutch engaged the engine is unhooked but the wheel is still hooked to the transmission.
Dave
1967-69 Vietnam Vet
Life Member DAV
Patriot Guard Rider
zimco is offline
post #4 of 8 (permalink) Old 02-10-2012, 05:17 PM
Happy Goldwinger
Anim8or Earl's Avatar
Model: GL1000, 1978 Black.
Mine will go into gear if I rock the rear wheel and wiggle the lever firmly.
Earl
Anim8or Earl is offline
post #5 of 8 (permalink) Old 02-10-2012, 05:51 PM
Yes, you are right. I got ahead of myself. I cannot think of anything de-coupling the final drive, so rocking the wheel should've worked. Could be bent/jammed fork(s) or something going on with the shifter mechs. It's got to be something something simple I woould think.
post #6 of 8 (permalink) Old 02-10-2012, 06:28 PM
Still Learning
newday777's Avatar
Model: 2008 GL1800 Level 4
Floor boards?
Stu
John 14:6 Psalm 118:19-29
Previous bikes
newday777 is offline
post #7 of 8 (permalink) Old 02-11-2012, 07:03 AM Thread Starter
zimco's Avatar
No floor boards
1967-69 Vietnam Vet
Life Member DAV
Patriot Guard Rider
zimco is offline
post #8 of 8 (permalink) Old 02-11-2012, 12:40 PM
Year: 2006
With the bike on the center stand , and the rear wheel of the ground , you should be able to turn the wheel with your rigth hand , and shift through all gears with your left hand. - if not something is wrong !
Can you turn the engine at all , when you use both hand on the wheel ?? (- should be wery easy , especcial if you have removed the spark plugs ).
Motor oil vs Transmission shifting... redwing52 Goldwing Technical Forum 6 08-01-2011 05:14 PM
78 gl1000 hard shifting chazwing Goldwing Technical Forum 9 10-07-2010 09:29 AM
Transmission GL1000 '78 rustybiker Goldwing Technical Forum 4 09-26-2008 10:34 AM
Shifting issues GL1000 b.pete Goldwing Technical Forum 26 09-22-2005 02:14 PM
'81 transmission shifting question orbit398 Goldwing Technical Forum 4 07-14-2005 09:20 PM
