I'm a Believer - Page 2 - Steve Saunders Goldwing Forums
post #11 of 21 (permalink) Old 08-14-2012, 08:50 PM Thread Starter
Village Whack Job...
Broke Winger's Avatar
Model: '81 GL1100 Interstate
Meh, I'm happy with them and happy with the price.
P.G.R. Member ID: 88374
Broke Winger is offline
post #12 of 21 (permalink) Old 08-15-2012, 12:52 AM
Just another ORF!
Dusty Boots's Avatar
Model: 92 1500 Aspencade
Actually Chromo .... you need 4 for the bike.
By the time you hunt up andget the mighty vac out and connected, you would already have one caliper bled and halfway through the 2nd.
- just another Rider
Dusty Boots is offline
post #13 of 21 (permalink) Old 08-15-2012, 02:33 AM
And if you have an 1800 it's seven or perhaps more.
Ken Bergen is offline
post #14 of 21 (permalink) Old 08-15-2012, 05:32 AM
LarryC's Avatar
I was trying to think why anyone would need more than 3, unless, like me, you have a sidecar. Then I happened to remember later model bikes have things like hydraulic clutches and such. Still not sure why the 1800 would need so many though.
Larry
84 Aspencade
79 GL1000 with VW carb
LarryC is offline
post #15 of 21 (permalink) Old 08-15-2012, 05:57 AM
galaxyhunter's Avatar
Model: 2000 Aspencade
Chromo wrote:
I like the idea of the speed bleeders, but kinda expensive at $7 each really. Needing 3 for 1 bike is $21 and can buy a good vacuum pump setup for about that.
Can use the vacuum pump on more bikes (or cars trucks) then instead of spending $21 per bike.
Also can use Vacuum pump to test for vacuum and leaks in stuff.
You can guess what I think the best value is I think LOL
Pretty simple concept for those speed bleeders, just a 1 way valve. A tiny spring, BB gun BB, drill bit, you could make your own fairly easy probably from a normal brake bleeder.
All it really amounts to is a BB seals the hole pressed down by the spring. Loosen bleeder and the bb seal the hole so air cannot enter but lets the pressure push through when the brake is pumped.
Simple one way valve is all it is.
A long piece of tubing for a tight fit on a normal bleeder and some Teflon tape to seal the threads with a 1 way valvae should work as well and be usable for all wheels. They sell those for like $2 at auto parts stores and you only need 1 of them!
What you are paying for is convienace. I sure wish I knew about these back in my Stock Car days whereI use a hand vac pump & would bleed the brakes about twice a month. Speed Bleeders are so much easier. I'm going to put them on my P/U truck the next time a brake job comes along.
Carl
Honorary Rhino
NASSIR 6 - NASSIR 7
NASR 10 - NASR 11
NASR 12 Host in Galena
old bikes:
71FX Super Glide
86 Aspencade
galaxyhunter is offline
post #16 of 21 (permalink) Old 08-15-2012, 06:08 AM
Longboater's Avatar
Model: 07 1800 "The Beast" 100K
Ken Bergen wrote:
Dusty Boots wrote:
Actually Chromo¬* ....¬* you need 4 for the bike.
Hmm, off the top of my failing brain I think the 1800 with ABS and clutch has 11. I bleed every fall with the annual and amazed at the crud that comes out for a sealed system.
After my run up to ONT and MI I will get a chance to get reacquainted with them.
Ned
MORE TAIL WAGGING and less barking please.
Heading for the sun set and checking the boxes along the way.
(until the keys are taken away)
Ned
Past rides:
USS TENCH (SS 417)
Yamaha 65
Honda 85
Kawasaki 125
Penton 125
Zuki 185
Husky 250
Honda VTX 1300
Enjoying Florida, come-on-down
Longboater is offline
post #17 of 21 (permalink) Old 08-15-2012, 10:31 AM
kah92340's Avatar
Year: 1981
Model: GL1100I
Thanks for the post, I've read the posts on them also and they do seem like they would work good and i hear a lot of good feed back.
From this forum now I've tried and love Seafoam, Delo Oil, Dyna Beads.
So in the future Progressive springs and speed bleeders.
Kim H
WARNING: It has been reported that Goldwing riding may be habit forming!
kah92340 is offline
post #18 of 21 (permalink) Old 08-15-2012, 10:49 AM
littlebeaver's Avatar
Model: 1981 Goldwing 1100 I
Yeh, I need to try one of these gizzmo's they look like a great invention, I have not seen these before, thanks fella's, good posting...I use my mitty vac and the container attachment to bleed my brakes..I got get me so of these though..
1981 Honda Goldwing 1100 Interstate
littlebeaver is offline
post #19 of 21 (permalink) Old 08-15-2012, 10:46 PM
muaymendez1's Avatar
Chromo.do you not see that just cracking them open a bit and pumping away and actually feel a spongy lever regain pressure is so convenient. I like that I can attatch a hose to the rear caliper crack the bleeder step on the pedal as I fill the reservioor up.no need to stop to refill.
I think we should chip in to get chromo 1 bleeder and make him a veliever
I have returned to the wonderful saunders forum after a 2 year hiatus. I realilzed the grass can never be greener.
muaymendez1 is offline
post #20 of 21 (permalink) Old 08-16-2012, 02:22 PM Thread Starter
Speed bleeders will make your mighty vac work even better. they keep air from coming in around the threads.
Dyna beads....now I am a believer. scotterichmond General Motorcycle Discussion Forum 41 05-26-2012 04:32 AM
So I'm a believer now. Broke Winger General Motorcycle Discussion Forum 8 05-05-2012 03:57 AM
I am a believer in Seafoam JIMBO83 Goldwing Technical Forum 27 07-09-2009 07:17 PM
"I'm a Believer"... tomw Goldwing Technical Forum 4 12-04-2008 08:06 PM
I'm a wing believer, home after 4K trip slickster General Motorcycle Discussion Forum 9 07-17-2008 02:02 PM
