I'm a Believer - Steve Saunders Goldwing Forums
post #1 of 21 (permalink) Old 08-13-2012, 03:55 PM Thread Starter
Village Whack Job...
Broke Winger's Avatar
Model: '81 GL1100 Interstate
I'd seen posts about them, seen people recommend them. But I never really bought into the hype. But when I was having so much trouble with my brakes I decided to try them.
Yesterday I rebuild my rear master cylinder...again...
Once I got it all back together and installed on the bike it was a simple matter of putting a clear hose on the speed bleeder and running the hose into an empty bottle. Bleeding took a while because the brake line I'm using is too long and therefore has a loop in it.
But even with the loop in the line the speed bleeder made simple if not short work of the bleeding procedure.
So to anyone with any doubts about them, go ahead and get them. They work...and boy howdy they work well.
P.G.R. Member ID: 88374
Broke Winger is offline
post #2 of 21 (permalink) Old 08-13-2012, 03:59 PM
FM
FM's Avatar
Model: 91-I
I've always used a knot in my bleeder brake hose.
It acts like a sink trap but for air. Makes it a one man operation.
Glad you got'r fix't.
floyd
FM is offline
post #3 of 21 (permalink) Old 08-13-2012, 06:31 PM
Senior Smart Aleck
erwjww's Avatar
Model: 97 GL1500 Aspencade
They are the "cats meow" aren't they. Glad your getting her straightened out.
1984 Aspencade/24000 miles
1997 Aspencade/ 54500 miles
Life is a highway, I'm gonna ride it all night long,
God Willin and the Creek Don\'t Rise!!
Darksider #1409
Patriot Guard Rider
Honorary Rhino
GWRRA
Honorary Newfie!! I have kissed the Cod (or whatever it was), downed the Screech, and shouted "Long may your big jib draw", so I am now a member of the Royal Order of Newfoundland Screechers.
JACK WHITE
erwjww is offline
post #4 of 21 (permalink) Old 08-13-2012, 08:47 PM
Chromo's Avatar
Well, they probably are pretty nice to have, but you have to remember they did not really help as much as it may seem.
The reason you could not get the brakes bled before was because the master cylinder was still bad, right?
Now that you rebuilt the master cylinder again and it hopefully no longer has any leak you could probably have bled just easy with a vacuum pump or other ways now.
When that master cylinder was still leaking I doubt the speed bleeders would have helped any then.
Chromo
I ride for FOOD
82 1100 riding sometimes, Red
Chromo is offline
post #5 of 21 (permalink) Old 08-13-2012, 10:10 PM
muaymendez1's Avatar
i had these on my 1200 and sold it that way . They guy who bought it didnt have a clue what they were after I explained it 4 times. i hate when others dont see the beauty in things I have added.
What sizes are the ones on the 1500s and where did you buy yours. i forget where i bought mine now.
I have returned to the wonderful saunders forum after a 2 year hiatus. I realilzed the grass can never be greener.
muaymendez1 is offline
post #6 of 21 (permalink) Old 08-14-2012, 07:54 AM
Model: Sold
IVe had them on my VTX 1300 since new and really like them, but the mityvac does just as good a job...I will however put them on the 1500...
Phil...
"Veni,Vidi,Velcro"(I came, I saw, I stuck around)
2006 Candy Black Cherry VTX 1300R (Darksider)
TennX is offline
post #7 of 21 (permalink) Old 08-14-2012, 08:09 AM
93Wing's Avatar
I got mine from there website and it was pretty quick.
http://speedbleeder.com/
Avatar: Republic P-47 Thunderbolt (Jug)
Gotta love that R-2800 and big ole paddle blade prop.....
I love the smell of 100 octane and oil in the morning.....
Just think, this is what the Germans saw barreling in at them.... (8) 50\'s blazin away....
Ride safe and watch your six!
93Wing is offline
post #8 of 21 (permalink) Old 08-14-2012, 08:30 AM
LarryC's Avatar
I put them on any vehicle that I work on the brakes. It makes bleeding brakes pretty much a one man job. I've been using them for years.
Larry
84 Aspencade
79 GL1000 with VW carb
LarryC is offline
post #9 of 21 (permalink) Old 08-14-2012, 04:36 PM Thread Starter
Actually, even with the master leaking I was able to bleed the system. In fact it took longer with the speed bleeders than without. But it was much easier.
post #10 of 21 (permalink) Old 08-14-2012, 05:28 PM
Chromo's Avatar
I like the idea of the speed bleeders, but kinda expensive at $7 each really. Needing 3 for 1 bike is $21 and can buy a good vacuum pump setup for about that.
Can use the vacuum pump on more bikes (or cars trucks) then instead of spending $21 per bike.
Also can use Vacuum pump to test for vacuum and leaks in stuff.
You can guess what I think the best value is I think LOL
Pretty simple concept for those speed bleeders, just a 1 way valve. A tiny spring, BB gun BB, drill bit, you could make your own fairly easy probably from a normal brake bleeder.
All it really amounts to is a BB seals the hole pressed down by the spring. Loosen bleeder and the bb seal the hole so air cannot enter but lets the pressure push through when the brake is pumped.
Simple one way valve is all it is.
A long piece of tubing for a tight fit on a normal bleeder and some Teflon tape to seal the threads with a 1 way valvae should work as well and be usable for all wheels. They sell those for like $2 at auto parts stores and you only need 1 of them!
Chromo
I ride for FOOD
Chromo is offline
Dyna beads....now I am a believer. scotterichmond General Motorcycle Discussion Forum 41 05-26-2012 04:32 AM
So I'm a believer now. Broke Winger General Motorcycle Discussion Forum 8 05-05-2012 03:57 AM
I am a believer in Seafoam JIMBO83 Goldwing Technical Forum 27 07-09-2009 07:17 PM
"I'm a Believer"... tomw Goldwing Technical Forum 4 12-04-2008 08:06 PM
I'm a wing believer, home after 4K trip slickster General Motorcycle Discussion Forum 9 07-17-2008 02:02 PM
