GL1100 Fuel Starved after fillling tank - Steve Saunders Goldwing Forums
post #1 of 5 (permalink) Old 05-12-2014, 02:35 PM Thread Starter
Year: 1990
Make: GL1500
Model: Aspencade
I purchased my new to my 1983 GL1100 last September. It had barely a quarter of tank of fuel when I bought it and only rode it a few times for a couple of miles. It would also start on the first bump of the starter.
I went ahead and filled it up with straight unleaded and parked it in the garage. A week later, I went to start her and she cranked over a number of times and finally hit. But then she would just barely idle and if I gave it any gas at all, it would die. If I let it run, it will eventually throttle up and then run as normal with no delay.
It sat over the winter and the same thing occured this spring when I tried to start it up. It would fire but barely run. If I gave it any gas, it would die as if it was fuel starved. I would let it sit there sputtering and try to give it an ever so slight amount of throttle. Eventually, it would get better and then run as normal. It works fine for the rest of the day and fires right up.
I let it sit for a couple of days and go through the same thing again. I play with the choke but it doesn't seem to make any difference. The previous owner told me he replaced the fuel pump but it makes me wonder if it's a fuel pressure issue.
Any ideas what I should look for or try differently?
Thanks in advance.
A brand new Gold Wing owner.
Dave in Pierre, SD
dvoeltz is offline
post #2 of 5 (permalink) Old 05-12-2014, 04:27 PM
Village Whack Job...
Broke Winger's Avatar
Model: '81 GL1100 Interstate
Sounds like a bad/disconnected choke cable to me. These bikes need to be choked at start up. If moving the choke lever makes no difference, the choke isn't working properly.
P.G.R. Member ID: 88374
Broke Winger is offline
post #3 of 5 (permalink) Old 05-12-2014, 04:35 PM
I suspect filling the tank loosed a bunch of crud and rust and sent it to the carbs.
post #4 of 5 (permalink) Old 05-12-2014, 05:11 PM
Just one of the guys
DougW's Avatar
I agree with broke, sounds like bad choke. If bike is running, move the choke, the engine should change. If no change choke is not working
Doug
DougW is offline
post #5 of 5 (permalink) Old 06-18-2014, 04:40 PM Thread Starter
Year: 1990
Make: GL1500
Model: Aspencade
It was indeed the choke, or lack of use, that was causing my hard starting problem. When I went to test drive it before purchasing it, the PO said he didn't have to choke it to get it started. The engine was indeed cold (80 degree day) and it started right off with no choke.
I was tryin to start it at 50 degrees without choking it and having problems. I finally applied full choke and it started fine. Talk about feeling stupid!!!!! Anyway, problem solved.
dvoeltz is offline
80 GL1100 fuel tank removal limpy45 Goldwing Technical Forum 3 02-21-2014 10:01 PM
GL1500 Carburetor seems fuel starved, need help DelArmy Goldwing Technical Forum 10 09-17-2012 09:38 AM
Fuel Starved? Goldwings2008 Goldwing Technical Forum 12 02-19-2008 01:20 PM
82 gl1100 fuel tank removal moospark Goldwing Technical Forum 9 12-29-2006 12:52 AM
GL1100 fuel tank exavid General Motorcycle Discussion Forum 4 10-23-2005 03:10 PM
