Darkside Suggestions - Page 3 - Steve Saunders Goldwing Forums
post #21 of 40 (permalink) Old 06-12-2014, 06:52 AM Thread Starter
Wildrat's Avatar
Originally Posted by Wildrat View Post
Ordered a Yokohama tire today, should be here Friday.
When I bring the tire and wheel to a tire place, do I need to tell them about the TPMS? Also what about balancing? I see some use those beads inside the tire, but I have read where it can interfere with TPMS.
Is there anything else I need to know before going to the shop?
Thanks
Wildrat/Mark
2010 Metallic Black GL1800 Audio Comfort Nav XM ABS model
Darkside #1629 (NRF 195/55R-16 Yokohama AVID ENVigor)
Wildrat is offline
post #22 of 40 (permalink) Old 06-12-2014, 07:53 AM
life is good
siouxindian's Avatar
Make: gl 1500 interstate
Model: 91 interstate
Originally Posted by youngnbald View Post
Rode last night and hit 5,000 miles now on this CT. Not bad for just over one month on it. Nipples on left side of tire are gone and the right is almost scrubbed.
Starting to practice low speed cornering. Left isn't hard to scrape the pegs, but right turns take a little more effort. Car tire is holding up to the test!
i thought my wife and i rode a lot . 5000 in a month is riding a lot LOL !
life is good.
siouxindian is offline
post #23 of 40 (permalink) Old 06-12-2014, 08:15 AM Thread Starter
Wildrat's Avatar
Thanks
Any Takers?
Wildrat/Mark
Wildrat is offline
post #24 of 40 (permalink) Old 06-12-2014, 08:53 AM
dedgar's Avatar
Year: 2005
Model: GL1800 30th year anniversary model
Yes, do tell them about the TPMS.
I don't know about beads interfering.
Very funny, Scotty. Now beam down my clothes. - James Tiberius Kirk
Good health is merely the slowest rate at which you will still die. - Anon.
Don't worry about old age. It doesn't last very long. - Anon.
Common sense doesn't seem to be all that common anymore. - Me (an adaptation of Voltaire's quote)
Why do today what you can put off till tomorrow. - The Procrastinators Code
PHD - taking your BS to a higher level
dedgar is offline
post #25 of 40 (permalink) Old 06-12-2014, 09:08 AM
youngnbald's Avatar
Model: 2006 Comfort & Navi
That isn't a norm. I had a few trips and also took off on a 2000 mile iron butt ride. Waiting for it to be certified yet. Kind of funny that I delivered a pre bought motorcycle tire while learning the CT. Love the tire and returned from a trip this weekend. No issues again.
Mark
Current Bike: 2006 GL1800 with Comfort and Navi
Certified Iron Butt Rider #58,607
SaddleSore 1000 (1000 miles in 24 Hours)
Bun Burner 1500 (1500 miles in 36 Hours)
SaddleSore 2000 (2000 miles in 48 Hours)
Completed May 11, 2014
Lake Michigan 1000 (1000 miles in 24 hours)
Completed May 16, 2015
Honorary Kanwings/Wild Rhinos
Double Darkside #1555
Rear Tire: NRF 195/55R-16 Yokohama AVID ENVigor
Front Tire: Rear tire design Michelin Pilot ACTIV 130/70-18 M/C 63H
youngnbald is offline
post #26 of 40 (permalink) Old 06-12-2014, 01:08 PM Thread Starter
Wildrat's Avatar
1) If someone here used the tire beads how many ounces did you put in the rear?
2) Also what beads did you use?
3) I looked on Amazon and I see beads that people have used for their 1800 but they are all complaining about the tube to that goes over the valve is too big. What did you all do?
4) I found a shop that will put my tire on for $7.50. I assume that I go ahead and let them air the new tire up and then when I get home let the air out and put the beads in the tire. Is this correct?
5) The Dunlop MT I took off is 180 60 16, the new tire is 195 55 16, am I going to have any issues or will the width and height on the new tire be about the same as the old?
I have my rear tire off. I put it on the lift and removed tire. The tire looks bad, it has thread, but it is way more worn on one side and it has rides where the tread is deepest.
Wildrat/Mark
Wildrat is offline
post #27 of 40 (permalink) Old 06-12-2014, 07:07 PM
Wangmaster's Avatar
Model: 08 GL1800 Air Bag
1) If someone here used the tire beads how many ounces did you put in the rear? 3 oz in the rear, 2 in front.
2) Also what beads did you use? I used Dynabeads
3) I looked on Amazon and I see beads that people have used for their 1800 but they are all complaining about the tube to that goes over the valve is too big. What did you all do? I had the guys put them in the tire as they mounted it. Not sure, but I don't think they lost any
5) The Dunlop MT I took off is 180 60 16, the new tire is 195 55 16, am I going to have any issues or will the width and height on the new tire be about the same as the old? I could not get mine up in the fender well on a stand. But I'm pretty sure others do. I laid the bike over and it fell right in.
Wangmaster is offline
post #28 of 40 (permalink) Old 06-12-2014, 07:16 PM Thread Starter
Wildrat's Avatar
Thank You Very Much for clearing these last few questions up for me.
I did order the beads, they will be here in a few days. I will wait and bring the beads with me to the tire shop and hopefully they will have done the beads before.
Again Thanks!
Wildrat/Mark
Wildrat is offline
post #29 of 40 (permalink) Old 06-12-2014, 07:49 PM
A 195/55 fits in pretty easy, I ran 205s for a long time and they fit but it is a struggle getting them past the lug studs. Go straight up from the bottom and move the bottom of the tire to the right, push up then swing it to the left to button it in.
post #30 of 40 (permalink) Old 06-13-2014, 05:19 AM
youngnbald's Avatar
I had to let the air out of the tire to get my 195 in. Could not get past the lugs without letting the air out.
Mark
Gone to the Darkside - NMWingRider General Motorcycle Discussion Forum 4 05-17-2014 06:39 PM
The Darkside for me. odies Goldwing Technical Forum 99 04-27-2012 10:30 PM
Darkside neilrupp General Motorcycle Discussion Forum 14 02-15-2012 08:12 AM
Has anyone from the Darkside ever gone down? wpgfire General Motorcycle Discussion Forum 34 06-11-2010 06:45 PM
I went to the Darkside norton General Motorcycle Discussion Forum 23 05-29-2010 06:24 AM
