engine block painting - Steve Saunders Goldwing Forums
  • 1 Post By BrianInPA
post #1 of 9 (permalink) Old 10-12-2015, 07:03 PM Thread Starter
Metal99's Avatar
Year: 1986
Model: GL1200 SEi
I need some feedback on whether I should use aircraft remover on the engine block and repaint the whole thing, or just kind of go with how it looks now? The paint has chipped away a bit mostly around the head gaskets.
Thoughts and opinions welcome.
\'86 GoldWing Aspencade SEi
\'84 Shadow VT700C -sold
\'83 Wife
Metal99 is offline
post #2 of 9 (permalink) Old 10-12-2015, 09:27 PM
well, seeing as how you have it all apart, I would probably have it shot peened and then spray paint it with the appropriate paint.
post #3 of 9 (permalink) Old 10-12-2015, 11:11 PM
blackknytecnc's Avatar
Year: 1985
Model: 1985 GL1200 LTD
You will likely find stripper to be a major PITA for that job. If you're gonna strip it blasting is the best option.
If you're going to do a clear laquer like factory you'll have to go to bare metal. If your going to do paint though, maybe just sand and feather the chips, then paint over what's there.
Either way, I'm always in the "paint it" crowd.
blackknytecnc is offline
post #4 of 9 (permalink) Old 10-12-2015, 11:33 PM Thread Starter
Metal99's Avatar
Year: 1986
Model: GL1200 SEi
thanks
looking at the shot peening stuff, seems a bit much for just getting it up and running again. I do like the feathering out the chipped parts and just go with it that way.
\'83 Wife
Metal99 is offline
post #5 of 9 (permalink) Old 10-13-2015, 12:58 AM
What I did was cleaned up the whole motor, then sprayed the front pieces that get rock damage. The little scrapes and bruises got some sanding and cleaned with alcohol, then I sprayed some paint into the lid of the can and touched the spots up with a brush.
post #6 of 9 (permalink) Old 10-13-2015, 11:26 AM
BrianInPA's Avatar
I scrubbed mine with scotch-brite while cleaning it. That removed the loose paint, removed the dirt and grime, and left me a surface that was ready to repaint. I sprayed the entire engine, and 2 years later, the paint is still holding tight and looking good.
Metal99 likes this.
Brian
BrianInPA is offline
post #7 of 9 (permalink) Old 10-15-2015, 05:58 PM
I stripped one with oven cleaner, just trying to clean it some but it took the paint right off, so I painted it.
post #8 of 9 (permalink) Old 10-16-2015, 04:37 PM
last child's Avatar
Model: 2010 GL 1800
Scuff,clean and shoot. I will get some guff for this but Harley makes
a silver paint for their engines ( spray bomb at near $ 20.00 ) If you can find a better paint report here.
last child is offline
post #9 of 9 (permalink) Old 10-17-2015, 08:57 AM
Year: 1985
I've always had great luck with duplicolor engine enamel. The trick is to be uber gentle assembling and as soon as you get it together fire it up, get it good and hot, and keep it that way for a while. When it cools it's hard as a rock. Just don't use it on air cleaner parts and such that don't get very hot.
engine block shredding UNY_Pete Miscellaneous Forum 4 10-27-2011 11:16 PM
GL 1100 block or engine jimbo1145 For Sale/Wanted Forum 6 04-01-2007 01:14 PM
engine block mark3 Goldwing Technical Forum 3 08-13-2006 07:13 PM
painting GL1000 engine block Kiwikid Goldwing Technical Forum 4 08-17-2005 12:38 AM
Engine Painting Newfiewinger Goldwing Technical Forum 7 02-19-2005 02:37 PM
