Trailers - Page 2 - Steve Saunders Goldwing Forums
post #11 of 47 (permalink) Old 12-09-2015, 06:08 PM
jobe05's Avatar
Model: 1500 & 1800
If you lengthen the tongue on the HF trailer by 18", you can put whatever configuration for a box you want on the top and it will tow just fine as long as you keep the load balanced, and slightly tongue heavy. Generally, a spare under the tongue and a cooler on it makes it tongue heavy, which is better than to light.
Honorary Rhino.......
jobe05 is offline
post #12 of 47 (permalink) Old 12-09-2015, 07:31 PM
rayjoe's Avatar
Originally Posted by mshiler View Post
Thanks now I know what to expect. I think I can handle those types of mods. I actually like your trailer. I might end up trying to build something like yours. I know I'll start with putting a carrier on it at first because I have that sitting there not getting used. Then I would attempt to build the full box. My father-in-law was a carpenter so I think I should be good building that part when I'm ready.
To get a perfect fit on the lid. Build an enclosed box. Measure down the sides 4 or 5 inches or however tall you want the lid to be. Then cut around the circumference to create the lid.
I usually build an internal frame to add strength.
Rayjoe
rayjoe is offline
post #13 of 47 (permalink) Old 12-09-2015, 08:45 PM
Ghost Rider 2's Avatar
I have heard that if broke down bearings and seals are very hard to find for the harbor freight trailer.
1980 GL1100 Standard/ with Vetter upgrades
2005 Honda Shadow Aero 750 wife (Better Half)
2002 Honda 1800 trike wife (better half)
2003 Honda 1800 everyday bike 95,000+
2014 GL1800 called midnight riding just a little it waiting for me to retire. (soon)
Ghost Rider 2 is offline
post #14 of 47 (permalink) Old 12-09-2015, 09:38 PM
I have a set of Bearing Buddies that will not fit the HF wheel hubs.
I then went to a RV trailer support house and looked at all of the Bearing Buddies that are available.
The tech guy there told me that no Bearing Buddie will fit a HF trailer, that they get requests every week for bearings and hub covers.
So, don't loose that hub cap on your HF wheel....
I will later get some different wheels and standard hubs for it.
right now, it rolls down the road just fine....
Cleaned the bearings and packed with new grease, should be good for a couple of years now.
post #15 of 47 (permalink) Old 12-10-2015, 07:31 AM
mshiler's Avatar
Year: 1985 GL1200 LTD and 1979 GL1000
Make: Honda Goldwing
Model: 1985 GL1200 LTD
Now that is good information. I never even thought about doing that for the lid. Thanks for the great info. Now I can't wait to start this project, but first my planned work on the bike this winter. Hope to convince the wife to let me start this sometime next summer.
mshiler is offline
post #16 of 47 (permalink) Old 12-10-2015, 02:36 PM
Year: 1990
Model: 1990 GL1500
I have a Harbor Frieght 40"x 48" trailer I bought a while back... My steering head bearing were bad and I would get a wobble arounf 65 mph... A friend who had a GL1800 towed it at 75 to 80 with no wobble... I have towed it with my accord and it tows true... It came wirh a cheeeeeeep cargo pod on it that I am going to build a cargo box to replace the pod... That will haul my camping gear just fine and at freeway speeds...
Bodasefus aka Russ Lawrence
Some days the Dog,,,
Some days the Hydrant...
bodasefus is offline
post #17 of 47 (permalink) Old 12-10-2015, 08:15 PM
Apatz's Avatar
Year: 2013
Make: GL1800
Model: 2013 Navi Comfort
Pulled mine on a cross country trip this past summer and hope to do it again next year. Absolutely no problems.
2013 GL1800 Comfort/Navi
2014 Harbor Freight Tag-a-Long
Currently stuck in Las Vegas, Nevada
Previous bikes (in reverse order) include:
Harley 883 Sportster
Honda GL1100 Interstate
Honda 750A Hondamatic (second best bike I ever owned)
Honda CB450
Kawasaki 900 Z1
Suzuki GT380
Honda MT125
Apatz is offline
post #18 of 47 (permalink) Old 12-11-2015, 12:01 PM
Knob's Avatar
Year: 2003, 1993 and 2004
Make: Yamaha, and two Hondas
Model: 1993 Aspencade and a 2004 1800 Roadsmith Trike
I bought new bearings for my PiggyBacker this summer and I believe they fit the HF also. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Knob
Knob is offline
post #19 of 47 (permalink) Old 12-11-2015, 07:35 PM
jlaframboise's Avatar
Model: GL1500A
I bought the tag-along and never regretted it. I just got back from a summer long adventure and it handled so well, I forgot it was back there, which is a very common statement for this trailer. As you can see, I made no mods to the frame at all. Since I was going to be only packing about 200 lbs, I removed one of the leaves off of each spring. I cleaned and repacked the bearings. They were torqued down way too much and the lubricant they had is not meant for actual use. It is a non flammable protective coating because the trailers can't be shipped with bearing grease. The only other mod I made was to add a tongue jack. If you look closely, you will see that I didn't weld a rack for the cooler. I drilled a hole through the lip of the lid on each side of the cooler so I could hook a bungee cord through them. The tie-down kept it from bouncing. For 10,000 miles, it never tried to shift once. Some people said that I should get rid of the 8" wheels and go with 12" because the bearings would get too hot. I would feel both hubs has part of a routine inspection when I stopped and they were very cool to the touch. The tires are still in very good shape. I bet they'd make that trip again. I'll try to post a pick of it here.
jlaframboise is offline
post #20 of 47 (permalink) Old 12-11-2015, 11:11 PM
Unofficial Youtube Addict
Happytrails's Avatar
Model: 1991 Goldwing SE Anniversary Edition
Those trailer projects look like fun.
"riding is good therapy"
Happytrails is offline
trailers Champ General Motorcycle Discussion Forum 1 08-06-2008 12:44 PM
Trailers bobo Goldwing Technical Forum 18 07-24-2008 04:09 PM
Trailers... Muskoka Winger General Motorcycle Discussion Forum 7 07-16-2008 06:46 AM
Trailers Bagmaster Miscellaneous Forum 15 06-12-2008 01:20 PM
Trailers manx black cat General Motorcycle Discussion Forum 36 02-20-2005 04:40 AM
