Winter Storage - Page 2 - Steve Saunders Goldwing Forums
post #11 of 16 (permalink) Old 12-24-2015, 05:41 AM
CrystalPistol's Avatar
centerstand on a 1500 puts more surface area pressure on the front tire, while the rear is suspended off the ground
Thats a recipe for flat spotting the front tire!
But it's next to no pressure ..... as in "just reach down, grab tread, and easily pull front tire around".
...(Candy Spectra Red )
CrystalPistol is offline
post #12 of 16 (permalink) Old 12-24-2015, 10:30 AM
Year: 94
Model: 1500 SE
but does anyone actually do that?
With the exception of Darksiders, motorcycle tires are not car tires~
Parking it for months on the sidestand isnt great either, Im just saying for BEST results
simply support the front end while its on the centerstand for winter!
AND drop the tire pressures a little,,drop 10psi
OR buy heated gear and keep riding- once the snow plow passes~
Aloha Tom is offline
post #13 of 16 (permalink) Old 12-24-2015, 12:41 PM
All I do is put it up on the Center Stand and plug in the Battery Tender.
When it is warm enough to go for a ride, crank it up and go for a long ride.
Come home and say "that was great"
One bad thing about "Winter Storage", things tend to get piled up on it.
post #14 of 16 (permalink) Old 12-24-2015, 02:24 PM
Just one of the guys
DougW's Avatar
Tom, I don't understand your reason for dropping the Tire Pressure, it seems counter intuitive to me.
Lowering the tire pressure will give the tire a larger contact area on the ground which means it has a larger flat spot on it. Having the tire at full pressure should keep it more round which should make for a smaller flat spot, if it flat spots at all.
Doug
DougW is offline
post #15 of 16 (permalink) Old 12-25-2015, 10:24 PM
I would never reduce tire pressure for storage. If anything, I'd maybe inflate them to max on sidewall.
post #16 of 16 (permalink) Old 12-26-2015, 11:07 AM
Year: 94
Model: 1500 SE
higher tire pressure creates a smaller contact area with the ground
Lowering the pressure allows more tire area- flattening the `point` so there is no small, high spot on which to center all the pressure
Ask anyone who transports race cars and find they lower the pressures,,even for parking the race car overnight when not on its jackstands- those totally prevent flat spotting!
Winter Storage samsdad42 Goldwing Technical Forum 8 11-24-2011 11:00 PM
Winter storage happer General Motorcycle Discussion Forum 40 11-16-2011 09:40 PM
Winter Storage LSC9901 Goldwing Technical Forum 25 11-04-2011 11:38 PM
Winter Storage fysty-1 Goldwing Technical Forum 3 10-29-2006 01:49 PM
Winter Storage chief43 Goldwing Technical Forum 15 11-12-2004 02:32 PM
