What octane gas do you run on? - Page 3 - Steve Saunders Goldwing Forums
 11Likes
post #21 of 39 (permalink) Old 06-03-2017, 08:59 AM
Power Guy's Avatar
Model: Aspencade 1500
Originally Posted by Peter Goldwing View Post
There you go PG. I edited your post for a clearer picture
Lol. For sure. I guess someone has to run the high octane. If they did not run it...they would not make it
Power Guy is offline
post #22 of 39 (permalink) Old 06-03-2017, 09:02 AM
Professional Curmudgeon
Davek's Avatar
Model: GL1800 ABS
I seem to get a few MPG better on 91 octane. Not sure if the Colorado altitude makes a difference with the octane.
God gave his Arch Angels weapons because even the Almighty knew you don't fight evil with tolerance & understanding.
Davek is offline
post #23 of 39 (permalink) Old 06-03-2017, 09:57 AM
Model: 2013 Goldwing
The only ethanol free gas I can get is expensive and 91 octane. I tried a few tanks, didn't notice an improvement in mpg or performance so went back to less expensive 87 octane and 10% ethanol. Seems to run good.
Bob Simon
St. Paul, MN
'13 Goldwing Current bike as of April 2013!
'98 Goldwing
'86 Wing
'79 Wing
GS650 Suzuki
500 Enduro
MNWingrider is offline
post #24 of 39 (permalink) Old 06-03-2017, 07:19 PM
OldSchool_IsCool's Avatar
Year: 1982
Model: Interstate
I knew someone was going to mention ethanol sooner or later.
Bruce
Current Bikes:
74 CB750 K4
77 CB550 K3
82 CM250C
Past Bikes:
What?? SELL a bike??
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
PGR since 2011
OldSchool_IsCool is offline
post #25 of 39 (permalink) Old 06-03-2017, 10:04 PM
The higher altitude, thinner air, less compression, makes the need for high octane even less. You must be in a low part of the state to even get 91 octane.
post #26 of 39 (permalink) Old 06-04-2017, 02:08 PM
Model: 1993 GL 1500
I had an 1985 LTD that ran better and got better mileage on 91 octane so when I got the 1500 I was buying 91 for it. After reading here that the 1500 was lower compression and didn't need the 91 octane, I tried some 87 octane and the bike runs better and gets better mileage. Also it cost less for each fill up. I buy Chevron gas most of the time but now what ever is available work fine. I was in Northern Calif. last week and I saw a sign that said next gas 97 miles and the last station I had past was a few miles back down the road so I kept going I had all ready gone about 100 miles on that tank, well that sign was not right it was about 125 miles to the next gas. So I made it but it took 5.7 gal to fill her up that's as close to running out as I want to get. The last 40 miles or so the gauge was sitting on empty and I was running hunkered down behind the windshield for less drag and running about 65 mph. I kept talkin to my self about how I should have just gone back to that station and filled up when I had the chance. That's what happens when The Old Lady don't come with me! LOL
Jerry Burns is offline
post #27 of 39 (permalink) Old 06-04-2017, 02:58 PM
Power Guy's Avatar
Well there you go. What ever makes you happy is all that really matters. Let's ride!
post #28 of 39 (permalink) Old 06-04-2017, 03:11 PM
Just one of the guys
DougW's Avatar
Did the low fuel light come on?
When my light comes on I still have about 20 miles or so left in my 1500 trike.
If you haven't done it, put a gallon of gas in a can the next time you are getting low and ride until the light comes on, and even until she runs out, then you will know for sure what you have left. You will be amazed at how far down the gauge goes before you actually run out, on most of these it says empty way earlier than it should.
CrystalPistol likes this.
Doug
DougW is offline
post #29 of 39 (permalink) Old 06-04-2017, 04:00 PM
I carry a 1 gallon jerry can of spare fuel with me.
I once put 6.2 gallons in the tank near Oark, AR
that did it for me, I knew I needed to get fuel before I got there, and spaced completely out and passed the refueling point.....
that jerry can is exactly the dimensions of the right side saddlebag toward the rear. you cant even see it when the door opens.
post #30 of 39 (permalink) Old 06-04-2017, 06:59 PM
CrystalPistol's Avatar
87 octane BP with "invigorate".
...(Candy Spectra Red )
CrystalPistol is offline
Gas octane dlfenny Test Forum 5 08-27-2014 02:00 PM
Gas octane, GL1100 tater Goldwing Technical Forum 12 08-02-2013 06:52 AM
GL1200 Gas... Regular or High Octane? hdwest Goldwing Technical Forum 2 04-09-2013 03:44 PM
GL 1200 Gas Octane To Use warfels Goldwing Technical Forum 21 01-03-2011 01:39 AM
regular octane gas?? Psalmist Goldwing Technical Forum 15 01-10-2008 08:05 AM
