Flat rear tire help - Steve Saunders Goldwing Forums
post #1 of 13 (permalink) Old 06-11-2017, 05:16 PM Thread Starter
Year: 2012
Model: Nav & ASB
Flat rear tire help
I have a question, I had my first rear flat tire on my Goldwing while riding on a highway with a shoulder. I wasn't able to use the kickstand or the bike would fall over. I carry a 2"x4"x4" wooden block in case I'm parking on a hillside to use under kickside. So I had my wife place it under bike in front of rear flat tire and pulled up on it. That helped, but wasn't enough. But from there with her help I was able to get the center stand down. It was ALL we could do to do it. My question is any advice for me in the future to handle that situation? I would of been screwed if I was by myself. Thanks for any input. RideSafe
Buster55 is offline
post #2 of 13 (permalink) Old 06-11-2017, 05:38 PM
Air up the rear shock.
post #3 of 13 (permalink) Old 06-11-2017, 06:10 PM
rayjoe's Avatar
Stand
Somewhere on one of these forums I saw a short adjustable stand that attached to the engine guard. It was designed to be carried on the bike.
Maybe someone with a better memory will find the link.
Rayjoe
rayjoe is offline
post #4 of 13 (permalink) Old 06-11-2017, 06:23 PM
You'll not be going anywhere until the tire is fixed so why not lay it down on the crash bars?
Ken Bergen is online now
post #5 of 13 (permalink) Old 06-11-2017, 06:33 PM
cihilb's Avatar
Model: 2012 Pearl White
Rayjoe
Here's a picture of it.
I made one to carry in case I had to pull over on the berm of an interstate. Put it on the right side to keep air turbulence from pushing it over. Also works well in you have the bike on a ferry. The rocking motion can't flip the bike.
rayjoe likes this.
cihilb is offline
post #6 of 13 (permalink) Old 06-11-2017, 08:02 PM
1800s don't have air shocks.
post #7 of 13 (permalink) Old 06-11-2017, 08:04 PM
Really? Honda's sure gettin' cheap.
post #8 of 13 (permalink) Old 06-11-2017, 09:48 PM
I should explain further, they have a hydraulic actuator that adjusts the spring rate. It doesn't raise the rear like an air shock does, at least not as much. It only increases or decreases the spring rate for the amount of load.
post #9 of 13 (permalink) Old 06-11-2017, 10:31 PM
Screw's Avatar
Model: GL1200 and GL1100
Before you lat it over on the crash bars turn the fuel off. I think thats what I would of done though. Then I would put a Run Flat car tire on it!
Screw is offline
post #10 of 13 (permalink) Old 06-12-2017, 06:18 AM
It's an 1800, fuel injected, no fuel shut off, not needed.
I do agree about the tire.
Using a plug 2 repair a flat on rear tire grizly Goldwing Technical Forum 33 12-29-2014 11:46 AM
I have a flat rear tire RB Goldwing Technical Forum 31 12-02-2009 06:50 PM
Flat tire on '09 with TPMS-Broken sensor in rear tire barb and dale Goldwing Technical Forum 13 07-15-2009 11:09 PM
GL 1100 rear flat tire 1 of U Goldwing Technical Forum 9 05-22-2009 09:31 PM
flat tire dredrush General Motorcycle Discussion Forum 8 09-03-2006 08:55 PM
