How Often Do You Change Your Rad Coolant? - Steve Saunders Goldwing Forums
 7Likes
post #1 of 12 (permalink) Old 09-06-2017, 12:21 AM Thread Starter
John Plank's Avatar
Year: 2003
Model: GL 1800 W Trike kit.
Ya know,,,, Honda says that we should change our coolant every 2 years. I've had a 2006 Escape for 6 years, and I have never changed the coolant. So,,,, why should I change the coolant in my 2003 1800, every 2 years? Just curious.
John Plank is offline
post #2 of 12 (permalink) Old 09-06-2017, 12:29 AM
Every two years! Wow!
Yeah, let it go for 4 years. That will save you nearly $3 a year.
I don't know how much work is involved on an 1800, but I'll bet it's not that much.
Anyway, maybe it's best to be safe.
post #3 of 12 (permalink) Old 09-06-2017, 05:07 AM
Honda type 2 coolant is good for 5 years or 60,000 miles. the maintenance schedule is full of ridiculous intervals.
DBohrer likes this.
post #4 of 12 (permalink) Old 09-06-2017, 08:54 AM
joe in calif's Avatar
I change it in a motorcycle every 2 years. Most cars how are 100,000 miles intervals for coolant and spark plugs. the 1500 and 1800 Gold Wings are easy to do. The couple V twins I have owned, Shadow, VTX and the Kawaswak Vulcan Nomad are a little more difficult because of the location of the fller neck.
A NEW START ON 1/20/2017
joe in calif is offline
post #5 of 12 (permalink) Old 09-06-2017, 11:06 AM
Year: 94
Model: 1500 SE
Have to carefully read the coolant bottles these days. Some say 5 year- heavy duty, others 2 to 3 years.
Its the additives that go bad and change the PH to acidic, in an aluminum environment....hmmmm
even acura/honda owner book says 7/100 on OE coolant in the engine now. Replacement honda coolant- use for only 5 years!
whats up with that?
Coolant is relatively cheap- under 15$ for a gallon does the bike, so every 2 years regardless of miles ridden.
If the coolant says approved for Honda (cage) its fine in the Wing.
Thats a silicone free coolant.
Aloha Tom is offline
post #6 of 12 (permalink) Old 09-06-2017, 11:25 AM
Our 2007 Pontiac Vibe has never been changed, but I did add some makeup coolant a couple years ago, when a hose came loose
I bought some of those test strips, and need to go out and check it out and see how it is "right now".
NASR 12 in Galena, IL
post #7 of 12 (permalink) Old 09-06-2017, 12:37 PM
Come on guys!!? It's 12 bucks for more than enough coolant and maybe a half hour's work. Just change the damn stuff and move on, worry free.
Well, worry free about the coolant, anyway. .
post #8 of 12 (permalink) Old 09-06-2017, 02:11 PM
OldSchool_IsCool's Avatar
Year: 1982
Model: Interstate
I change mine every 2 years or every head gasket change, whichever comes first!
Bruce
Current Bikes:
74 CB750 K4
77 CB550 K3
82 CM250C
Past Bikes:
What?? SELL a bike??
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
PGR since 2011
OldSchool_IsCool is online now
post #9 of 12 (permalink) Old 09-06-2017, 10:24 PM
Year: 94
Model: 1500 SE
Just because you never changed a fluid, doesn't mean its not time for it!
How old of brake fluid is ok in the cage? and the Wing gets new brake fluid every...?
Please share the coolant PH test strip results with us John, maybe we (me) have been lied to by big advertising once again
post #10 of 12 (permalink) Old 09-06-2017, 10:52 PM
DBohrer's Avatar
Model: '99 Gold Wing SE
I use the following:
Honda Genuine HG, Long life, Type 2, 50/50 Prediluted, “Blue” Antifreeze. Protects for 5 years and 60,000 miles.
At 220k miles my Wing is not complaining and neither am I. Works for me....!
There is maintenance and then there is "over maintenance" with no tangible gain. Folks should do whatever allows them to sleep good at night......!!
Suppliers (parts houses) love those who "over maintain". Keeps the funds circulating from one pocket to another pocket..........!
AZgl1800, DaveO430 and Doug B. like this.
DBohrer is online now
GL1100 coolant change littlewing Goldwing Technical Forum 5 01-22-2011 09:04 AM
Coolant Change Frozen Goldwing Technical Forum 3 03-03-2010 05:37 AM
1500 coolant change bobby690_11 Goldwing Technical Forum 6 10-11-2009 09:56 PM
GL 1800 Coolant Change 2goldwings Goldwing Technical Forum 18 01-03-2008 05:37 PM
coolant change radioniwde Goldwing Technical Forum 3 06-18-2006 06:33 AM
