roll a home - Steve Saunders Goldwing Forums
 3Likes
post #1 of 35 (permalink) Old 05-24-2018, 04:08 AM Thread Starter
fireshine's Avatar
Year: 2012
Model: 2012 1800 nav/xm
roll a home
purchased a roll a home camper, it has electric brakes on the camper, the wiring plug is a flat 5 wire plug which i converted my round 5 wire on my bike to a flat 5 wire the wiring on the trailer also has a 2 pin connector for i believe is the trailer brake unit in the camper i believe i need to run a hot wire from my bike to that connector with a automatic reset breaker in line with the hot wire. i noticed on my bike trailer wiring there is a red heavy wire that runs with the other 5 wires, i think i can power up the trailer brakes with this wire as long as it has a auto reset breaker. was wondering if anyone else has a roll a home with electric brakes and how their wiring was set up and what there controller was set at. thanks for the info.
sanity,
2014 roll a home wide
2017 africa twin
fireshine is offline
post #2 of 35 (permalink) Old 05-24-2018, 04:49 AM
Year: 1992
Model: Aspencade 1500
Are you sure you don't need a brake controller on the bike? Usually electric trailer brakes require a proportional voltage.
Peter Goldwing likes this.
RambozoClown is offline
post #3 of 35 (permalink) Old 05-24-2018, 05:11 AM Thread Starter
fireshine's Avatar
Year: 2012
the controller is mounted in the trailer it is a Tekonsha Prodigy P2 Trailer Brake Controller -
sanity,
2017 africa twin
post #4 of 35 (permalink) Old 05-24-2018, 06:52 AM
Just one of the guys
DougW's Avatar
It would seem logical that the red extra wire would be 12Vpower to the brake controller. After you verify that is what it is for, putting the self reset breaker sounds like a good idea.
For my 12V to the trailer, I put a 12V relay that was activated by the accessory circuit and a fuse.
Doug
DougW is online now
post #5 of 35 (permalink) Old 05-24-2018, 10:58 PM
that is the same brake controller that I bought for my Suburban, I got the P3 instead of the P2, but they are the same technology.
works terrific!!!
post #6 of 35 (permalink) Old 05-25-2018, 05:50 AM
Year: 1989
Model: GL1500
For trailer brakes you need 2 extra wires to the trailer typically. Standard colors would be Red (+12 constant) and Blue (0V - 12V Variable brake control). The red would charge the breakaway battery. That trailer may not have one, its not big enough to require brakes.
jpay42 is offline
post #7 of 35 (permalink) Old 05-25-2018, 07:51 AM
DougW's Avatar
His setup is not typical, the brake controller is in the trailer.
The trailer I had with brakes was set up this way and it worked marvelously. Once you have the gain set properly on the trailer it is muss, no fuss.
Doug
DougW is online now
post #8 of 35 (permalink) Old 05-25-2018, 08:54 AM
Year: 1989
Model: GL1500
Gotcha, Never thought of that. You would still need a brake signal wouldn't you. If you use one of the lights, blinkers would make the brakes pulse.
jpay42 is offline
post #9 of 35 (permalink) Old 05-25-2018, 10:41 AM
Well yes,
but the trailer has brake lights, you just connect the controller to the brake light wire.
post #10 of 35 (permalink) Old 05-25-2018, 01:15 PM Thread Starter
fireshine's Avatar
Year: 2012
yes all that is already in the trailer and connected from the factory what is out by the ball hook up is a 2 wire connector i beleive for power to the controller and ground i was wondering if anyone else on the forum has a roll a home with brakes so they could fill me in how they have theres hook to the bike the hook up for the controller is already done i will sent some picks of what i am looking at thanks
sanity,
2017 africa twin
roll-a-home fireshine General Motorcycle Discussion Forum 5 01-12-2018 09:02 PM
Home at Last, Home at Last, Thank God we are Home at Last! MNWingrider Miscellaneous Forum 7 06-21-2016 06:41 PM
I are home, we am home, home is good Richardrwg General Motorcycle Discussion Forum 6 08-07-2009 09:58 PM
Roll Call. Events 107 05-31-2005 01:51 PM
