Belly Pans - Page 2 - Steve Saunders Goldwing Forums
 18Likes
post #11 of 26 (permalink) Old 10-02-2018, 09:29 PM
CrystalPistol's Avatar
I bet a fellow could build a nice one of 1/4" steel plate (or thicker) and jack under that, just use aluminum aftermarket as a pattern to start from?
Weight would lower a bike or trike's center of mass, maybe better handling, …. like result when we added thick brass belly pans to our HO slot cars.
...( Candy Spectra Red )
'85 GL-1200 Aspencade
...( Vintage Red )
CrystalPistol is offline
post #12 of 26 (permalink) Old 10-02-2018, 10:32 PM
Originally Posted by OldRider2 View Post
Thanks, that's why I asked guys. I know it's water cooled but couldn't see where I'd get into a situation where I'd need the pan.
All it takes is the front tire flipping a small sharp object off the road and sending it through the oil filter or the coolant reservoir, none of us foresee getting into a situation, but it happens. That's why I wear a helmet.
post #13 of 26 (permalink) Old 10-03-2018, 02:16 AM
can't remember who it was now, but earlier this year, someone reported hearing a noise, and noticed water under the bike when he parked.
the overflow reservoir was busted.
it just isn't worth the chance of it happening...
get a belly pan, even a cheap one will stop most stuff from breaking that plastic overflow reservoir
NASR 12 in Galena, IL
post #14 of 26 (permalink) Old 10-04-2018, 04:07 AM
fireshine's Avatar
Year: 2012
Model: 2012 1800 nav/xm
The McGuver diamond plate works well on my 2012 dont notice any over heating problem been in Oklahoma month ago pulling a roll a home in 90* temps didn't notice any heat problem just like the thought of rocks not hitting the motor.
sanity,
2014 roll a home wide
2017 africa twin
fireshine is offline
post #15 of 26 (permalink) Old 10-04-2018, 05:54 AM
Andy Cote's Avatar
There is also a guard for just the coolant tank. V&P Accessories sell one that just covers the tank and not a full belly pan.
DARKSIDE #1500
2015 Goldwing - basic black
Ham Extra Class AC1R
Andy Cote is offline
post #16 of 26 (permalink) Old 10-04-2018, 09:39 AM
I just kind of like having all of the bottom side covered up...
I read of one post where a rider somehow, caught a spike or something similar, and it punched a hole in the engine block and let all the "good smoke out"
apparently he did not see the Low Oil Pressure light and when the engine locked up, he figured something was wrong.?
post #17 of 26 (permalink) Old 10-04-2018, 06:19 PM
mcshepard's Avatar
Year: 2012
Make: Goldwing
Model: 2012
I have had a belly pan on both my 1800. Run over a wrench that punched a hole in my oil filter. My Harley neighbor was glad to come get me said he had never towed a Wing before. So I think it is worth it.
AZgl1800 and Pastot like this.
mcshepard is offline
post #18 of 26 (permalink) Old 10-05-2018, 01:02 PM
Year: 2008
Model: 2008 GL1800 Comfy
I put a louvered stainless steel pan on.. It was relatively easy to install. The ‘front’ portion of it removes easily for access during an oil and filter change. The enclosure of the pan as it may relate to heat is not an issue. I am convinced it provides a layer of protection for the expansive under belly of the bike, I think it looks cool, and it adds at least 15 miles per hour to the top end as you twist the noisy stick to full grin
AZgl1800, flylow, rayjoe and 1 others like this.
AJAugust is offline
post #19 of 26 (permalink) Old 10-05-2018, 03:43 PM
DBohrer's Avatar
Model: '99 Gold Wing SE
AZgl1800 and rayjoe like this.
DBohrer is offline
post #20 of 26 (permalink) Old 10-08-2018, 11:49 AM
rayjoe's Avatar
Belly Pan
Originally Posted by Rickf1985 View Post
I figure that if I hit something big enough to damage the bottom of the engine then that is going to be the least of my worries! Even with a belly pan it is most likely going to throw me.
Not true Rickf1985. A sharp rock can knock a whole in the engine case and you might not even feel it. Loss of oil would be the only indication.
The bottom of the engine case is relatively thin.
Rayjoe
rayjoe is offline
Hey! Who's the guy making GL1800 Belly Pans on the forum? AZgl1800 General Motorcycle Discussion Forum 4 01-24-2015 08:01 AM
Belly pans Wings of Fire General Motorcycle Discussion Forum 11 09-29-2014 11:44 PM
Belly pans for the 1500 flw General Motorcycle Discussion Forum 15 10-20-2010 10:22 AM
Belly pans - What holds 'em on - friction?? miles.from.nowhere Goldwing Technical Forum 10 04-30-2007 01:04 AM
Belly pans for 1800 Rich Steinel General Motorcycle Discussion Forum 9 09-18-2005 08:55 AM
